Cobalt ss T/C exhaust popping after 5k?
Old Apr 7, 2013 | 06:52 PM
Kordas93's Avatar
Put a 3" MPX catback exhaust with a ZZP catted DP on my '09 T/C. Now when I floor it in second, after 5k my exhaust starts popping and wont reach redline as fast due to the popping. Also, it throws a CEL once it's starts popping. Any suggestions on what it might be? Or how to fix? Thanks.
Old Apr 7, 2013 | 06:53 PM
K-Train04RL's Avatar
what cel does it throw? are you running e85?
Old Apr 7, 2013 | 06:59 PM
ssyellow's Avatar
Sounds like the car is breaking up/misfiring. Pull the code for starters.
Old Apr 7, 2013 | 07:07 PM
JapEatr's Avatar
South Central *********
Sounds like spark blowout
Old Apr 7, 2013 | 07:35 PM
N1ckateen's Avatar
check the code and most likely you need new plugs. if you're tuned you may need to get a revision since you went from stock piping to 3"
Old Apr 7, 2013 | 08:05 PM
Kordas93's Avatar
No I'm not tuned
Old Apr 7, 2013 | 08:18 PM
Kordas93's Avatar
No I'm not tuned. Just intake, charge pipe, TR8 front mount and now this exhaust
Old Apr 7, 2013 | 08:32 PM
how many miles. how are plugs, what are codes, what the condition of your injector seals.
Old Apr 7, 2013 | 08:40 PM
Kordas93's Avatar
Plugs are less than 1k. Autozone read "random cylinder misfire" but the car does not feel like it. Until it start popping. Any ideas?
Old Apr 7, 2013 | 09:12 PM
kzak104's Avatar
put stock plugs in and get a tune, having that many mods with a stock tune is stupid. intake messing with your fuel trims could be playing a role.
Old Apr 8, 2013 | 12:22 AM
Kordas93's Avatar
Is it weird that it only pops at high RPM's? Or is that something blown plugs do?
Old Apr 8, 2013 | 01:37 AM
kzak104's Avatar
not weird, put stock plugs in and get a tune.
Old Apr 8, 2013 | 01:42 AM
cranemaster's Avatar
Same thing happens when you mess up a no lift shift with he same code. You are getting it all the time... So spark plugs!
Old Apr 8, 2013 | 05:09 PM
N1ckateen's Avatar
lnf's run factory spark plugs period! change them about every 10k miles and with that amount of mods get a tune NOW. not only will your car run like it's supposed to but you'll gain around 70whp and about 100wtq.
Old Apr 8, 2013 | 09:02 PM
krispy's Avatar
Running rich at WOT due to power enrich + hot exhaust temps = boom in exhaust
Do you know what the code is? If you don't there is no reason not to own this:
Koolertron F-12 ELM 327 OBDII PC Car Diagnostic Scanner : Amazon.com : Automotive Koolertron F-12 ELM 327 OBDII PC Car Diagnostic Scanner : Amazon.com : Automotive
and download Torque or another OBD scanner app on the smartphone I'm assuming you have
Old Apr 11, 2013 | 09:39 PM
Kordas93's Avatar
Update:
put the stock plugs back in. Runs fine, cleared the code and hasn't popped back up yet. Got on it a little bit and no popping. But it's raining where I am and I wasn't tryin to die haha. Thanks guys
Old Apr 11, 2013 | 09:42 PM
kdub1492's Avatar
What part of Illinois you from? I'm from Joliet area..
Old Apr 11, 2013 | 11:34 PM
Kordas93's Avatar
Rockford area
Old Apr 11, 2013 | 11:41 PM
damastah's Avatar
try seafoaming the car....
also, check plugs see what they look like...
also get a tune. if budget is your problem. get a budget trifecta tune.
your problem sounds like detonation which is the worst thing possible for our cars... but very common as well...
i don't think just putting an exhaust on will cause this problem..
Old Apr 12, 2013 | 07:35 AM
idrinkV8's Avatar
Could be missing an injector seal
Old Jul 27, 2013 | 07:31 PM
Mxman38's Avatar
I had about 9k on my car with a trifecta tune on 93, i was beating on it for about 30 minutes straight in 95 degree weather and right after 5k it did the same thing. As soon as i let it cool down i took it back out and it drove perfect.... i think it has something to do with the exhaust temps, or maybe IAT's and the car retarding the timing... i never threw a code though
GaryGibblez
Jan 14, 2020 10:35 AM
How to Guide
57
Oct 15, 2015 11:56 AM
OrngBalt
Sep 16, 2015 07:45 PM
Rayray2781@gmail.com
Sep 9, 2015 10:40 AM
