code p0101
Bt I have a concern, I did fix. 2 boost leaks on both couplers of the intercooler when I did take it to the shop bt it was fixed, now that it's fixed it's throwing the code?? Doesn't make no sense.... never had this issue before, I fixed boost leak and now it throws the p0101 code and I'm boosting higher psi than before be cus I wasn't able to go past 22 psi with the leak now with it fixed it boosts 29 psi when we were tuning it bt needed some things done to keep up with that amount of power now I fixed it and it's boosting fine bt throwing the code ?? Sketch
Nah sorry to clarify he works with hp tuners he's a local tuner referred by alot of people tuned by him
Is there any way you could get your hands on the most recent logs and email them to me? I'd be curious to take a look and see if I could help out a bit further. The more data I have (or we as a whole here) have, the better help you will be able to get. As a cohesive unit, we've basically seen just about every scenario there is when it comes to a P0101 code. There are always exceptions I'm sure though.. lol
It's highly unlikely to be caused by the intake unless there's a leak between the maf pad and inducer housing. It's possible, just highly unlikely. The inducer side of the compressor is the draw side NOT positive pressure side of the system. Again, it's still possible, just not likely.
You've asked this a couple times now so I'm guessing you think it's a likely cuplrate. Just put the stock air box on and see if it resolves anything. It's an easy enough thing to do so try it out and let us know. Maybe you'll get lucky.
I boost leak tested the car tho? The car builds boost just fine and will hit full boost, 24 psi , other times it'll throw the code and limp mode... I had 2 huge boost leaks I fixed on ic piping, and it really had a boost leak then and it never threw this code so now I fixed the boost leak bt now it throws this code...? Doesn't make sense, I'm going to tuner today to diagnose car.. possibly the maf need calibration in the tune
Yes we did since I was to going to replace intercooler I was certain it was cracked, bt tested it and intercooler is fine, would my car still build boost if I had cracked or broken intercooler??
I checked bpv on turbo wasn't leaking, fixed 2 leaks that were on intercooler couplings , had all couplings replaced on ic, boost leak tested car had no more leaks... where else can a leak be coming from??
How could it have boost leak bt it's boost g target boost just fine ??
Last edited by mikeluis92; Jan 10, 2015 at 03:14 PM. Reason: Automerged Doublepost
I'm still waiting on a response to this. A log file would be extremely helpful in locating an issue, whether it be mechanical or elsewhere.
