Coilover kit for a 2009 Cobalt SS?!?!
Old Oct 31, 2009 | 05:40 AM
Josh Leverington's Avatar
Canada Coilover kit for a 2009 Cobalt SS?!?!
Anyone got suggestions on a good coilover kit for 2009 SS?
Old Oct 31, 2009 | 10:59 AM
Boosted_Cobalt09's Avatar
no one has really put them on these cars yet. 1 member has bg coilovers and likes them but the directions are not very good. ottp is testing out the pedders xa coilovers. i would wait a little bit until more products get tested.
Old Oct 31, 2009 | 01:14 PM
fakameanrepresent's Avatar
i have the full megan coilover, i like how it feels. the spring rate is good, 6kg front and rear.
Old Oct 31, 2009 | 01:39 PM
scottherbert's Avatar
I'm using a Ground Control coilover kit on my 09 SS coupe and am pleased with it. My setup is a little different because I'm using Koni shocks/struts -- but the few changes I had to make on the install were very easy. I also have B&G camber plates, which took a little modifying because Koni struts have a 14mm bolt, but I drilled and tapped the parts and they work just fine.
I picked Ground Control because a: they were the least expensive and b: they use 'standard' sized (2.5" ID) coils. So I'm able to get any length and any strength coils without any major problems. I have a set of 550lb x 2.5" ID x 6" springs (front), a set of 650 lb x 2.5" ID x 7" springs (front or rear), a set of 360lb x 2.5" ID x 7" springs (front or rear) and a set of 250lb x 2.5" ID x 8" springs (front or rear). Ground control supplies 6" long springs up front but you could use anything from 6-8 inches up front. They supply 8" long springs in the rear, but I have used 7" without problems. Bottom line, you have choices. I use the 8" 250s and the 7" 360s on the street. The 550s and 650s are strictly for autocross.
Here's the Ground Control link for the Cobalt -- http://www.ground-control-store.com/products/search.php -- about $400.
Here's a link for springs (remember, 2.5" ID) from both Eiback and Hypercoil -- http://www.eshocks.com/hyp_make.asp -- normally $55-$60 per spring.
Here's a site for the B&G systems Cobalt camber plates -- which can now be purchased separately -- http://b-gsuspension.blogspot.com/20...ces-their.html
Gravana has the camber plates for sale -- http://www.gravanatuning.com/5848/1/...e_2.0_FWD.html -- they cost about $200.
Most coilover vendors use their own, 'proprietary' springs so you're very limited about your choices if you pick someones unique coilovers.
Scott
Old Oct 31, 2009 | 11:43 PM
you can get custom spring rate for the megan coil. just need to go on their website for more info.
Old Nov 2, 2009 | 06:45 AM
Chris@CTA's Avatar
I'm going to install a set of D2 Racing coilovers. A friend of mine that had an 07 SS coupe tried out a set for me, liked them, so now it's my turn. I just haven't gotten around to installing them. My friend just traded in his SS coupe so the coilovers were taken out prior. I have his used D2 coilovers for sale, has less than 2000kms on them, with original box. PM me if your interested.
These are pictures of my set.
Old Nov 2, 2009 | 12:50 PM
Thank you all fo the suggestions!!!
Old Nov 3, 2009 | 04:17 PM
mkriebs's Avatar
BC racing (not B&G) is what I am looking to install. Tein is developing some Basic's. Otherwise I don't see anything that is good enough for me. I liek the KONI and Ground Control coilovers... might have to look into that.
Old Nov 3, 2009 | 11:27 PM
How much you looking for the set??
And are those adjustable camber plates on the top of the shock?
Last edited by Josh Leverington; Nov 3, 2009 at 11:27 PM. Reason: Automerged Doublepost
Old Nov 3, 2009 | 11:46 PM
northvibe's Avatar
Pedders coil overs > all
Old Nov 3, 2009 | 11:50 PM
You run them on your turbalt?
Old Nov 4, 2009 | 06:37 AM
Chris@CTA's Avatar
Based on where we are (Canada) ,the used set that I got back from my friend, I'll take $700.00CAD plus shipping. The new set worked out to around ~$1200.00CAD after I paid the customs and taxes and shipping.
The front struts have adjustable camber plates. The struts/shocks have adjustable dampening.
Old Nov 4, 2009 | 07:57 AM
northvibe's Avatar
I did not have that much money, I got the pedders springs. I also am trying to set my car up for time attack in the stock class and the rules are changing for 2010 and when you get coil overs it gets slightly detailed as to what you can and cannot have so I just said screw it springs it is.
Old Nov 5, 2009 | 09:37 PM
RossGo's Avatar
I am the test fitter for the Pedders XAs with pillowball mounts and camber plates. (2009 SS coupe)
Just waiting for a rear sway bar for install and then I will do a writeup
Old Nov 5, 2009 | 10:29 PM
mkriebs's Avatar
I want the XA's.
Old Nov 5, 2009 | 10:32 PM
rallyracer's Avatar
be sure to take lots of pics for all of us
Old Nov 5, 2009 | 11:26 PM
Stamina's Avatar
HHR with Pedders coilovers on the skidpad (0.97g on the pad):
http://www.youtube.com/watch?v=gKy8MHOuWw4
HHR on the track: (unknown if Pedders springs or coilovers)
http://www.youtube.com/watch?v=GeVhC90hY7I
Old Nov 5, 2009 | 11:37 PM
mkriebs's Avatar
Wow... can't wait til these hit the market. Any time frame?
Old Nov 6, 2009 | 10:37 AM
RossGo's Avatar
My bar is bent, just waiting on paint.
Once I get that, the whole setup will go on
I have the only set of XAs with pillowball mounts and camber plates, I believe
I also have powergrip endlinks and an OTTP street sway bar
I think they are waiting for a few cars to put a few months on them before mass production
ashalle2
Sep 17, 2015 04:58 PM
dennis69
Sep 17, 2015 12:52 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
Josh@ottp
Sep 8, 2015 10:18 AM
PotatoLvrd
Sep 2, 2015 01:25 AM
