Dealer hype or could this be true?
Old Mar 14, 2013 | 04:46 PM
Nfamous60's Avatar
Ok so I have my car Bac are the fuel pumps in yes are the lines new yes is the issue fixed.... Lol hell no, so now dealer is telling me that it's either my ECM or my cam lobe. Not sure how I would flatten a cam an I just started driving my car after siting for 10 months and my ECM is new from my last warranty issue. I was talking with C miller and I'm going to try flashing my ECM again, then I'm going to install my Zzp cam with the bigger fuel lobe so I know for sure the hpfp is being used, even the fuel rail pressure sensor is new, my stock tune has been on my car since before I deployed.
Old Mar 14, 2013 | 08:41 PM
kzak104's Avatar
they should be able to tell if the cam lobe is flattened by taking out the hpfp and LOOKING at the cam lobe... if its like a vw fsi engine that is
Old Mar 14, 2013 | 09:02 PM
killtank's Avatar
Wtf! How does the cam censor look? Any cells?
Old Mar 14, 2013 | 10:43 PM
Nfamous60's Avatar
Cam lobe is fine took off valve cover and inspected, startin to think fuel pressure regulator got 55 psi with regulator plugged in cleared codes and unplugged the connector still reads 55psi, I think it's stucc open maybe idk I'm out of options
Old Mar 14, 2013 | 11:04 PM
killtank's Avatar
Are you running rich or lean?
Old Mar 14, 2013 | 11:56 PM
Nfamous60's Avatar
Rich as hell man
Old Mar 15, 2013 | 10:13 AM
killtank's Avatar
Did luke data log you? Maybe your maf is wrong since you relocated it
Old Mar 15, 2013 | 12:47 PM
Nfamous60's Avatar
Fuel rail pressure is 55 psi on hptuner not the MAF had this code pop up before the installs it started when we swapped my valve cover.
ricklovin93
Aug 27, 2016 06:35 PM
agentirons
Oct 16, 2015 02:11 AM
bigdogstokes16
Oct 8, 2015 10:28 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
