Do urethane bushings make noise?
Old 05-28-2010, 01:43 PM
Highbeamz's Avatar
I'm tired of my sway bar bushings making squeaking/creaking noises in the winter so I'm thinking of picking up some urethane bushings to replace them. I know for sure it's the bushings because the dealer replaced them, they were dead quiet, then started to act up after a few thousand kms.
First off, am I going to run into the same problem with aftermarket urethane bushings?
Does anyone know a vendor you can buy them from? I've seen them for the SS/SC, but isn't our sway bar thicker than the SS/SC, or not at the end links?
Old 05-28-2010, 03:50 PM
08SStc's Avatar
yes, urethane bushings do make noise when cold. had them on sway bars and other parts on several vehicles
Old 05-28-2010, 03:58 PM
SSlobalt's Avatar
Everything makes noise when it's cold.
Old 05-28-2010, 05:55 PM
Highbeamz's Avatar
Well that sucks. I'm trying to find a solution to this. I haven't heard any successful solution except to change over to the stock cobalt (LS/LT) bushings, but I don't want to compromise handling, or even be changing them every spring/fall.
Old 05-28-2010, 05:57 PM
thedude411's Avatar
its summer. ***** warm. deal with this **** in november lol
Old 05-28-2010, 06:19 PM
Highbeamz's Avatar
That's the plan, but I need to see what I'm going to need for that time. I'm also looking at installing a block heater this fall too, lol. It had a few rough mornings this last winter.
Old 05-28-2010, 06:22 PM
Do_WorkSS's Avatar
Prothane makes front sway bar bushings. i think they're like 23 or 25 mm. if you wanted to spend a little extra money, just by the Eibach front and rear sway bar set and they come with new poly bushings.
06MetallicBalt
08-17-2021 03:40 PM
biniecki
10-25-2015 02:23 PM
dennis69
10-20-2015 04:49 PM
jimbofug007
10-02-2015 12:06 PM
Stuff
10-01-2015 05:47 PM
Quick Reply: Do urethane bushings make noise?
