downpipe bolt size
Old Apr 20, 2012 | 03:23 PM
YesYestotheSS's Avatar
downpipe bolt size
anyone know that the four bolts and nut sizes are that connect the dp to the header
Old Apr 20, 2012 | 03:30 PM
BPacak's Avatar
Vtec Rep
i think it was 15mm, i dont remember.
Old Apr 20, 2012 | 03:34 PM
Sox-Fan's Avatar
Got Brakes?
15mm for the nut is correct.
Old Apr 21, 2012 | 03:55 PM
anyone know the bolt size off hand?
Old Apr 23, 2012 | 08:27 AM
Gremlin85's Avatar
I just had experiene with this over the weekend helping install a DP. Had to buy new bolts and nuts.
They are M10X1.50 and you need them about an inch long for the bolts. We went to Lowes and brought one of the bolts/studs with us that came out of the turbo outlet. Double check by going to the Hardware section and thread it into the guide, but I'm 99.99999% it's M10X1.50.
Old Apr 23, 2012 | 02:51 PM
Hey thanks man. Good looks.
Old Apr 23, 2012 | 03:01 PM
If you confirm that for me and send me the part numbers of the bolts and nuts that be great
Old Apr 23, 2012 | 03:08 PM
Gremlin85's Avatar
Like I said, you can get some M10X1.50 bolts and nuts from the hardware store or if you want you can order factory replacement studs from GMPartsEast for about $3.09 each -Part Number for the stud is 609870. It looks like the Nut IS in fact an M10X1.50 and you can get that for about $3.59 each - Part Number 032594.
Here's the diagram....
Old Apr 23, 2012 | 08:22 PM
word thanks, couple questions. autozone has these size bolts but some are 30mm, 40mm, 50 mm, whats the difference?
Old Apr 24, 2012 | 09:16 AM
Gremlin85's Avatar
No problem Just helping out when I can.
Honestly, I'm not too sure what the mm is, most likely length I would assume because 30mm is about 1 inch.
I'm no expert on bolts and nuts, I just brought one in to the hardware store to compare and it worked out for me lol.
Old Apr 24, 2012 | 09:35 AM
lol word. Did you end up replacing the gasket as well?
I thinking about doing that as well for giggles. Its a 4 dollar part.
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
