Driving juiced up SS TC..question
I was wondering what you guys were talking about with this PILL deal. Now I get it. When I had my 944T we used a vary small fitting with a small hole in it to dam up/retard the boost feed line to the ECU...ECU *sees* less boost...so you're *allowed* more. Gotta be REAL careful here though, as you're aware. I got greedy there and started blowing hoses..boots and fittings. If you stress those you're gonna get BOOST LEAKS! READ>>no free lunch baby. I guess most of you guys have duly compensated for the added boost
. BTW, that's a neat place for that..easy to put in take out.
at 24.5 up to 6k. every time i floor it i cringe. lol. just waiting for something to pop.
i am on a mission though. the 12's. once i hit 12's, i'm going back to the old tune and taking the pill out. (until i get charge pipes and t-bolt clamps).
i'm nervous. i'm all stock fittings and charge piping. spiking to about 29 and holding strong
MIG welding tips are an easy way to change restriction. .030 wire tip is really an .040 port. I checked it with some number drills I have a small set of. You have to be able to custom tune for the increased boost.
>24psi + long hard pulls = greater than average chance of piston ring land failures. GM engineers have posted in the past that the excessive heat causes the rings to expand greater than the end gaps allow causing them to gouge into the cyl wall, popping the ring lands.
I have ~41k miles so mine isn't that tight anymore anyway.
I went back to 2 range colder plugs to help lower the comb temps a bit since I never had any fouling with them.
YMMV.
YMMV.
Yep, I wouldn't boost that high (29 psi) on the stock lower CP, the rubber couplers were bagging out after 30k miles of boost when I replaced the lower CP with the ZZP & silicone couplers. Pics of new intake & CP in images link at left. .030 pill boosts 24 psi at 4500 rpm, tapers off to ~18psi at 7k with my current DAL tables. I could do more up top with a smaller 'pill' but it overspools the turbo quite a bit. I'm sure I could get back under 5 sec again on the ricer pulls.
The pill line runs from the boost control solenoid under the turbo to a fitting on the top of the scroll area of the turbo. The welding tip is 1/4 od and isn't going anywhere, at least on mine.
Thinking of replacing it with a needle valve if I can find something appropriate. A remote needle valve assembly from a larger model aircraft engine comes to mind. Quite precise.
Here's kinda what I'm talking about:
YMMV.
YMMV.
importkiller
Sep 30, 2015 07:18 PM
