E85
A tune is required. Power gains vary but around 20-40whp depending on how aggressive the tune is and what other mods you have.
I see you're in California, not 100% sure if you'll pass CARB if you tune the ECU
It really depends on how far you want to push the stock turbo if the larger lobe is needed. You can run lower boost and e85, but if you want to run 22-24psi and you're near sea level you need the extra fuel from the lobe. I was a fan of running e47, but it does require a little math and at least something to follow fuel trims to be sure your mix is close.
