First 1/4 Run in the 2010 TC
Old Mar 15, 2011 | 12:35 PM
ssblackstealth's Avatar
corn gas ftw....
Originally Posted by CobaltVenomSS
then ill do the same if not better
bahahahahahahahahahahahahahahahahahaahahahahahahah ahahahahahahahahaha
no lsd FTL, love ya buddy
Old Mar 15, 2011 | 12:38 PM
CobaltVenomSS's Avatar
i get a .5 second handicap
Old Mar 15, 2011 | 01:28 PM
bogalusahondakiller's Avatar
ok guys im still trying the trifecta launch control. with my car running the way it should now. I think the latest tune vince sent me had a big problem. i have the launch control up to 3700 and i still bog but if i launch myself i cant get ove 2k even slipping the clutch on the street. im gonna get with vince thursday and see whats happening.
Old Mar 15, 2011 | 04:34 PM
shobalt87's Avatar
I hate to be the one to say this but are you turning traction control off?
Old Mar 15, 2011 | 04:36 PM
shobalt87's Avatar
So I have an ongoing arguement with a few other cobalters and they seem to think lsd is only good for cornering and not straight line runs, thoughts?
Old Mar 15, 2011 | 04:40 PM
HHRSSouth's Avatar
How is one wheel losing traction and the other grabbing in a straight line not good?
Old Mar 15, 2011 | 04:49 PM
drewbroo's Avatar
Best in my sedan so far is a 13.2@106.6 Only mod is Tune and AB Mod. (Also done at 4900ft DA)
Old Mar 15, 2011 | 04:50 PM
Mike08ss/tc's Avatar
Originally Posted by shobalt87
Hey all, so finally made it out to a 1/4mi track to see what I could run and only got one pass in and was kind of disappointed.
60'...2.61
330...6.44
1/8...9.38
1/4...13.9@107.39
Whats the best combination as far as rpm's on stock tires for a good launch? I'm thinking that the 5k limited on launch control is a bad idea because it will either wheel hop like a champ or spin. Any input would be appreciated. *this run I left the line easing into first and second until about 2,500 rpms then slowly laid into it and still spun a bit until around 4,300rpms*
looking at your 60ft your spinning a little to much.
Old Mar 15, 2011 | 04:53 PM
Grishbok's Avatar
If my friends said that, id find new friends. y'know, the kind that know what their talking about and dont try to bs their way through things?
Old Mar 15, 2011 | 04:57 PM
rnjmur's Avatar
Originally Posted by Shibito
I went from idle on stock tires. You have a lot of time to pick up in that 60ft. I can see you going into mid 13's easy.
If you shave .4 off that 60' time you should be in the low-mid 13s easy.
Old Mar 15, 2011 | 04:58 PM
  #36
yea cant use launch control with it on lol...
Old Mar 15, 2011 | 05:00 PM
  #37
And on the lsd arguement I spin both tires straight line. I've done it numerous times in my car and i dont have lsd. I leave 2 solid tire marks through 1st and 2nd.
Old Mar 15, 2011 | 05:51 PM
  #38
shobalt87's Avatar
agreed, sometimes I wonder myself. Not sure whats worse that I started questioning myself or that they are BOTH senior members on this site....rut roo
Old Mar 15, 2011 | 06:08 PM
  #39
reefer_roids's Avatar
Originally Posted by devilbmxer120
I launched at 2500 on the stock tires with them at about 23psi. Launch control=fail. at least in my book. I run with ESC off. Got a 13.9 that way at 103. Minimal spinnage and NLS 1-2 and 2-3. Dunno how gms1 is but thats how i did it 100% stock
anyone know the 1/4 mile time with gms1?
Old Mar 15, 2011 | 07:50 PM
  #40
rukkee's Avatar
I cut a 2.1 on stock conti's ( i think i had 24 psi in the tires) leaving at 2200 rpm and ridding the clutch a little . 2.1 isn't anything that great but it really helps ET's (went 13.4 on my old superchips tune ...nothing to brag about) Some of you guys are trying to leave to hard at too high an rpm. I havent been back with the trifecta tune but when i do I'll be leaving at the same 2200 with nitto 555's
Old Mar 15, 2011 | 07:52 PM
  #41
rukkee's Avatar
I'm sure they vary but i've seen a lot of 13.6's . I'm sure someone has done better .... and worse
Old Mar 15, 2011 | 08:04 PM
  #42
corn gas ftw....
next track run om going down to 22 or so psi on the tires! lol
Old Mar 15, 2011 | 09:17 PM
  #43
shobalt87's Avatar
Did you pretty much have the clutch 1/4 of the way out and engage it right before green?
Old Mar 15, 2011 | 10:06 PM
  #44
rukkee's Avatar
I had it out just enough to be off the floor ...not moving the car . I can't remember exactly but from the time i engage the clutch enough to move the car ....till full engagement is about a full second or so. It's hard to explain but I kinda ride the clutch out just enough to keep it from bogging ....but get it fully engaged in 2 car lengths so I can get on the throttle as soon as i can .
Have you ever seen how a sport bike has to launch .... they keep the R's up and ride the clutch out ....it's kinda like that but not to that extreme.
Old Mar 15, 2011 | 10:10 PM
  #45
drewbroo's Avatar
This is also my technique
Old Mar 15, 2011 | 10:38 PM
  #46
wghyaes25's Avatar
Should work on launches before debating LSD vs no LSD
Old Mar 15, 2011 | 10:45 PM
  #47
rukkee's Avatar
My brothers old Z24 was an open diff. and it always spun posi in a straight line . I've also seen non LSD cobalt SS's spin posi on straight even road surfaces . I think LSD really shows up when picking back up on the throttle on corner exit ... non lsd cars will light up the inside tire . I'm no expert ...plus both my SS/SC and TC had LSD so i've never driven on without it to compare it to.
Old Mar 15, 2011 | 10:58 PM
  #48
DerekDTP!'s Avatar
Originally Posted by alerosaint
Have anyone had the boost reduction done to their first gear in your tune?
wondering the same thing
Old Mar 15, 2011 | 11:02 PM
  #49
i will try the way yall launch when i go to the track this weekend again.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
dieGone
Oct 1, 2015 06:27 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
