First evidence of clutch slip :(
Old Oct 6, 2010 | 12:43 AM
importkiller's Avatar
So in WOT in 2nd gear today I noticed my clutch slipping (my rpms were climbing but my speedo was not). How long do you guys think I have till I need a new clutch?
Old Oct 6, 2010 | 12:46 AM
donkeyballs's Avatar
Were you at low rpm when you went WOT ? Mine will slip in 4th if i mash it at like 2000 rpm
Old Oct 6, 2010 | 12:50 AM
i was at about 3-4 in 2nd gear at WOT and aprox 22 psi.
Old Oct 6, 2010 | 12:54 AM
Time for a new clutch.. You can shift at high rpms and baby it and it should last awhile but that's no fun.. Lol
It could of been hot and you glazed it just do this and it might help it
Old Oct 6, 2010 | 07:57 AM
SSBalt's Avatar
Mine started slipping about a year ago. As far as i can tell it hasn't gotten worse. I'm not too agressive of a driver though. I just start out a lil over 4k if i plan to romp it. Works for me so far.
Old Oct 6, 2010 | 09:12 AM
Terminator2's Avatar
Mine has been slipping for almost 2 years now and it has actually gotten better over time so I would not worry too much about it.
Old Oct 6, 2010 | 09:59 AM
jb09ss's Avatar
Mine did that too. I actually slipped it bad on a 2nd gear clutch drop (don't ask me about that lol) and no slip ever since.
Old Oct 6, 2010 | 10:23 AM
BYT*SS*TURBO's Avatar
^That's how mine became "fixed" as well lol.
Ive never slipped in 2nd tho..
Old Oct 6, 2010 | 10:38 AM
X2. Tires rip loose in 2nd.
Old Oct 6, 2010 | 10:49 AM
mccullj's Avatar
ive been running mine like that for about a month now. it slips if i try to take off quick in first right after a start up. (i don't get on it after first start up, only when its warm) and it will slip if im at low rpm's and mash it. other than that, im still limping around on it
Old Oct 6, 2010 | 10:50 AM
This is the first time I have noticed any slip at all, later that night i did not get any clutch slip. The temperature is getting a lot colder here.
Old Oct 6, 2010 | 10:54 AM
cubaniche's Avatar
Yeah its weird, my clutch slipped more with lower miles than it does now. Dont forget its colder out so it may not have been quite ready for the pull. Not to mention that the colder air helps the power delivery a little sooner too.
Old Oct 6, 2010 | 03:48 PM
I am gonna make it last as long as I can, I need to save up for the exedy hyper single.
Old Oct 6, 2010 | 03:52 PM
Black SS/SC 06's Avatar
I'm still on the stock clutch
Old Oct 6, 2010 | 04:28 PM
And ours are better :P
Old Oct 6, 2010 | 06:55 PM
SSlobalt's Avatar
Which one did you go with, and did you use the ZZP rod?
Old Oct 6, 2010 | 07:06 PM
Ch1ck3n's Avatar
I know I'm probably an idiot, but it seems almost as though the clutch is designed to slip to protect engine internals... since anything over 350hp/tq gets to be a touchy subject for the stock transmission, its almost as if the clutch is a failsafe.
I digress, went out today for some MAF tuning and had 2nd slip pretty hard at about 2500rpms at a launch from a dig. The next time I got on it in 2nd it put all the tq to the wheels and burned rubber at like 50mph with no slip whatsoever. Weird stuff.
Old Oct 6, 2010 | 08:08 PM
Iam Broke's Avatar
Term is still on the stock clutch, I'm SPEC Stage2+ and ZZP rod. No slippage at ~390 wtq.
Spins the tires a bit in third at times tho.
Old Oct 6, 2010 | 08:29 PM
rukkee's Avatar
I've had mine slip in 3rd and 4th but never 2nd. Do you have a good set of tires?....mine spins in 2nd rather than slips the clutch . Did it slip after a shift or was the clutch fully engaged when you mashed the throttle?
It's weird that the first time you've noticed it is in 2nd..... that means its pretty bad. Usually you noticed it in 3rd and 4th long before it happens in 2nd. If that makes any sense lol.
Old Oct 6, 2010 | 08:40 PM
army_greywolf's Avatar
What is this clutch slip you speak of?
Old Oct 8, 2010 | 04:29 PM
slowbalt84's Avatar
i have a precision 50 trim and still on the stock clutch.
Old Oct 9, 2010 | 11:33 AM
emiller's Avatar
Mine slipped once in 3rd at around 4k. Guess I'll see how it goes and get better clutch sometime down the road if it gets worse.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
