Get a K&N Typhoon intake or get a ZZP LNF PCM tune?
Old 07-19-2014, 03:03 AM
Sl0wbaltSS's Avatar
Question Get a K&N Typhoon intake or get a ZZP LNF PCM tune?
Get the intake, orgasm the sound and run lean, or get a ZZP LNF PCM tune and get POWER! Also is GMS1 sensors needed for the 22PSI?
Old 07-19-2014, 08:25 AM
tuned08ss's Avatar
Same questions have been asked just in the past week. Search.
Just get all your bolt ons then get tuned
/thread
Old 07-19-2014, 09:47 AM
Speed_Thrills's Avatar
Tune. Easy choice.
And I believe it's 23.5PSI, and they require a tune adjustment.
Old 07-19-2014, 09:50 AM
Omiotek's Avatar
you need a tune for any intake on these cars anyways.
Old 07-19-2014, 11:32 AM
Shanedude's Avatar
Buy the tune and mod your stock intake box. Done.
Old 07-19-2014, 11:46 AM
If you going for zzp tune then you should prob get both together that way you can do the add on the k&n for 10 bucks
Old 07-19-2014, 12:17 PM
TylerJY's Avatar
I run the typhoon with no tune. Going to do downpipe and tune at the same time
Old 07-19-2014, 12:44 PM
tomj77's Avatar
ur not gonna run lean getting a intake. fuel trims will be a little out but u can run it. I did for a year before I tuned. if u wanna do it right get hp tuned by someone. u don't need gms1 sensors for 22 psi. the zzp tune is still a can tune, where as if u get hp tuned, save up money and get hp tuners and get a good tuner to remote tune u. u will be much happier.
Old 07-19-2014, 01:42 PM
Gimpster's Avatar
What tomj77 said.
I'm sure the billion other posts about this topic make this clear, but you realize while yes... the trim is off, the PCM has compensated that % to reach the target lambda. You aren't going to see a CEL/MIL or blow up your car with an intake like a K&N. That's the whole point of the trimming, because even all things being equal stock its not going to be 0% all the time in every environment.
Much ado about nothing for 99.99% of the population here.
Old 12-14-2014, 12:09 PM
Blue_Balt's Avatar
Just installed the ZZP LNF PCM and man what a difference. Car was quick stock, but now its on a new level.
TedSS
101
04-25-2016 10:46 PM
vjoel2011
10-02-2015 12:11 PM
bucks121
09-12-2015 07:39 PM
medic710
09-06-2015 08:53 PM
Quick Reply: Get a K&N Typhoon intake or get a ZZP LNF PCM tune?
