Help. engine getting KR after swapping head
Old May 25, 2016 | 05:23 PM
nathan112i's Avatar
after installing a head with valve springs i am getting large amounts of knock retard when i rev the engine or slight throttle when cruising. engine is timed correctly and there is nothing loose that could be rattling. any quick input of gas causes KR however i have none when i am bouncing off factory launch control. i get the exact same amount of KR(usually around 3-4) with or without the knock sensors disconnected. any thoughts or new ideas that cause this would be awesome.
Old May 25, 2016 | 05:49 PM
Ecu calibration issue, the ecu loves to set kr if it isn't completely happy.
Old May 25, 2016 | 10:32 PM
nathan112i's Avatar
still wondering on what the next step to fix it is
Old May 25, 2016 | 10:37 PM
Get your tune updated.
Old May 25, 2016 | 11:41 PM
nathan112i's Avatar
tried tuning it out but doesnt work
Old May 26, 2016 | 05:39 AM
It's not related to timing, the fact it was there with the knock sensors unplugged says it's not timing related. Your fuel trims can cause kr to show up (it's not actual kr, just the ecu is calling it not liking something kr), to quick of timing transition, to quick of cam tables, injection angle being incorrect, and the list goes on.
Old May 26, 2016 | 03:11 PM
T-Man's Avatar
I remember this from back in 09-10 when people were upgrading their valve train via springs/rockers/followers and it causing KR. I think it was BTF and PrincessTurbo that both experienced it. Maybe even OneBadBlueberrySC (may have spelled that incorrectly)
OP, I'd pull the valve cover and make sure everything is good. It's definitely a mechanical issue but not may not necessarily be a 'problem'
Old May 26, 2016 | 03:43 PM
nathan112i's Avatar
i have had the valve cover off and checked everything more times then i can count. lifters and rockers all all in good shape, i put the stock cams back in and it made no difference.
Old May 26, 2016 | 03:45 PM
blueLNFftw's Avatar
How off are your fuel trims?
Old May 26, 2016 | 03:51 PM
nathan112i's Avatar
ill have to find my datalog again, IICR it wasnt off by an absurd amount
Old May 26, 2016 | 03:53 PM
blueLNFftw's Avatar
Sometimes that doesn't matter.
Have you tried putting a stock or gms1 tune on it?
Old May 26, 2016 | 04:01 PM
Normally I'd agree with you, but it still shows KR when he disconnects the sensors. If the valve train was causing the sensor to register KR unplugging them would remove the KR.
If the OP isn't seeing an actual drop in timing (commanded vs observed) it's not actual KR, its the ecu saying there is something i don't like so i'm going to register KR. When I was on e47 I would get some KR just like the OP was indicating, I smoothed out my fuel trims and tweeked my injector angles and the KR went away. I found out it wasn't pulling timing before the adjustments, so I made them.
Old May 27, 2016 | 02:43 PM
nathan112i's Avatar
worst i see stft are -6. took it out for a log and it had a solid 9.7KR from 2500-4500rpm.
Jrocky
2.2L LAP Performance Tech
39
Feb 3, 2017 01:37 PM
Oscar1204
Apr 28, 2016 12:25 AM
Timnman
Apr 18, 2016 12:53 AM
redman2357
Mar 20, 2016 11:17 AM
Sharkey
13
Mar 19, 2016 12:43 AM
