HELP! Engine issue
Old Aug 16, 2013 | 07:24 PM
395 plus's Avatar
HELP! Engine issue
Car starts and idles as it should. I take off and when I shift to 2nd gear and step on the gas if I get even the slightest boost the car shakes and stutters and my aeroforce gauge shows misfires. The CEL will flash and then go off when I let off. The misfires all show on cylinder 1. It has the stock engine programming nothings changed. Only mod is the ZZP charge pipe and intercooler.
Heres what I have checked
1. I swapped coils and plugs no change
2. Checked all connections on charge pipes they are tight with no movement
3. Checked Compression 1-161 , 2-159, 3-156, 4-151
4. Plugs are gapped at .32 and are stock plugs and are new old plugs do same thing
5. CEL is misfire code p0301 and p0300
Any Ideas or anyone else had this Issue?????
Old Aug 17, 2013 | 12:58 AM
SSlobalt's Avatar
Well, you've checked everything we usually tell everyone to check, so I'm in to see the resolution.
Gunky valves, maybe.
Old Aug 19, 2013 | 11:35 PM
TheBoss8688's Avatar
Are you tuned? For the mods on the car?
Old Aug 19, 2013 | 11:41 PM
Well the p0300 is random misfire iirc, did you swap cylinder 1 coil pack for cylinder 2 coil pack? Or progress them all forward 1, so 1 to 2, 2 to 3 and so on? A leak down test will give you more information than a simple compression test. Also how many miles on the car and how long have you had the zzp parts on? (Miles and time)
Old Sep 10, 2013 | 10:41 AM
395 plus's Avatar
Dealer said MAF sensor was bad and said they checked all coils and plugs. Seems to be working now. Took the car back in a week later to have the valves top engine cleaning done. Car runs good and boost fine even with stage1 tuning and sensors in. Just have some off throttle misfires.
HEATON
Oct 16, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
