help! key stuck in the ignition.
iirc there should be a small compartment at the bottom of the steering wheel column
pull the cover/clip off and look for a small button and press it while pulling on your car key
that should get your key out
unless im missing something here
my LS cobalt i had used to shut off if i tilted the steering column all the way up and dropped it to the lowest position, didnt take alot of force at all. idk if my accident caused it or not
The issue is the cover that holds the springs against the tumblers is loose. There is a groove in the ignition switch housing. When you turn the key the pressure of the spring pushes the cover off and the springs fall out causing the key to stay in the ignition. took mine out and pressed the tabs on the cover in to tighten it and it hasn't happened since. that was 2weeks ago. Planning on taking it in soon for the recall though.
It happened at the worst time for me. Coming back from your lunch break and not being able to shut off your car. Then having to go and tell your boss that your car wont shut off and you have to take your car to the dealer.
happened to me two months ago. There is a dealership right across from my job. I pulled it into the service bay and stalled out the car. ALL the mechanics looked at me like i was a tool. I told the service guy what was wrong, he asked for my keys. the minute he asked he had a"that was a dumb question" look on his face. But it was fixed within a half hour :-)
Same thing happened to me in the fall. Dealer told me the same thing. They just repaired it and i was on my way. But I am going to go and get the recall done anyway. Don't know how long their fix will last.
