help! key stuck in the ignition.
Old Jul 18, 2011 | 06:40 PM
steviepc7's Avatar
Guys,
All the sudden I can't turn off the car or remove the key from the ignition. Wtf?! Anyone had this happen? What did you do??
Old Jul 18, 2011 | 06:49 PM
AndrewSS/TC's Avatar
Happened to mine. I disassembled the column and pulled ignition cylinder to get mine out
Old Jul 18, 2011 | 06:54 PM
sick_tight's Avatar
stealership! i believe theres a recall just like the powersteering. idk about getting it to shut off right now though
Old Jul 18, 2011 | 07:02 PM
Well to turn the engine off just stall it, then I'm sure there is a fuse for the battery You can pull
Old Jul 18, 2011 | 07:04 PM
sjc0013's Avatar
Window Licker
I wish I had a dollar for every car this has happened to.
Old Jul 18, 2011 | 07:18 PM
sick_tight's Avatar
haha i didnt pay attention to what kind of balt he was driving hahahaha hahaha
Old Jul 18, 2011 | 07:41 PM
steviepc7's Avatar
Lol yeah I stalled it. Just curious. Thanks guys ill hit the dealership up tomorrow.
Old Jul 18, 2011 | 07:49 PM
Philswrath's Avatar
iirc there should be a small compartment at the bottom of the steering wheel column
pull the cover/clip off and look for a small button and press it while pulling on your car key
that should get your key out
unless im missing something here
Old Jul 18, 2011 | 07:54 PM
That trick doesn't work in manual cars, at least it didn't for me. The ignition has an internal issue
Old Jul 18, 2011 | 07:58 PM
Philswrath's Avatar
awe i see, i used it on my car and my GFs balt, were both auto
anyway yeah disconnect that battery lol
Old Jul 18, 2011 | 08:00 PM
JaredMeyers's Avatar
it happened to mine except i could shut my car off the key just wouldnt come out. it wasnt a recall for my car so it cost like almost $300 to get fixed.
Old Jul 18, 2011 | 09:24 PM
sick_tight's Avatar
my LS cobalt i had used to shut off if i tilted the steering column all the way up and dropped it to the lowest position, didnt take alot of force at all. idk if my accident caused it or not
Old Jul 20, 2011 | 12:42 PM
steviepc7's Avatar
got it back from the dealer. there is a recall out for it.
Old Jul 20, 2011 | 01:02 PM
JaCobalt's Avatar
That happened to me last month. To it to the dealer next day and replaced it under warranty. The only recall they found was for the steering that was it.
Old Jul 20, 2011 | 01:07 PM
cobaltz06's Avatar
The issue is the cover that holds the springs against the tumblers is loose. There is a groove in the ignition switch housing. When you turn the key the pressure of the spring pushes the cover off and the springs fall out causing the key to stay in the ignition. took mine out and pressed the tabs on the cover in to tighten it and it hasn't happened since. that was 2weeks ago. Planning on taking it in soon for the recall though.
Old Jul 20, 2011 | 08:23 PM
BostiPB's Avatar
Same thing happened to me in the fall. Dealer told me the same thing. They just repaired it and i was on my way. But I am going to go and get the recall done anyway. Don't know how long their fix will last.
It happened at the worst time for me. Coming back from your lunch break and not being able to shut off your car. Then having to go and tell your boss that your car wont shut off and you have to take your car to the dealer.
Old Jul 20, 2011 | 08:33 PM
DillySS's Avatar
Just got this done. Sucks.
Old Jul 20, 2011 | 08:37 PM
mysweetSS's Avatar
happened to me two months ago. There is a dealership right across from my job. I pulled it into the service bay and stalled out the car. ALL the mechanics looked at me like i was a tool. I told the service guy what was wrong, he asked for my keys. the minute he asked he had a"that was a dumb question" look on his face. But it was fixed within a half hour :-)
Old Jul 20, 2011 | 08:38 PM
BigRyanJackson's Avatar
yup its a recall. new ignition cylinder under warranty. and to JaredMeyers...you got beat. 05-10 cobalts are covered..
Old Jul 20, 2011 | 11:26 PM
cobaltz06's Avatar
Got to work and had to stall the car. spent lunch taking column apart to pull switch and get my key out. didn't want anyone to take the car. Although all my coworkers say "who would steal a cobalt."
Old Jul 20, 2011 | 11:33 PM
mine wasnt covered i talked to chevy customer service and when they pulled up the recall screen the only one for my car was for the steering colomn and it had already been sone to my car
Old Jul 20, 2011 | 11:35 PM
Edubs's Avatar
Why does everyone stall the car out. Just pull the freaking fuel pump fuse...
Old Jul 21, 2011 | 12:19 AM
cobaltz06's Avatar
Cause it is quick and easy. If my car was an automatic I probably would have.
Old Jul 22, 2011 | 05:42 PM
imacho2's Avatar
mine just happened this second.
Old Jul 22, 2011 | 08:30 PM
Jellobriafra's Avatar
Uhhh...I'm kinda drunk but I feel that I can safely that you coworkers can go F themselves.
