i have no leaks
Old Jul 25, 2010 | 07:14 PM
ericgt79's Avatar
i have no leaks
SUKXOST does
Old Jul 26, 2010 | 10:00 AM
SSlobalt's Avatar
Now that's just plain mean.
Old Jul 26, 2010 | 10:56 AM
ericgt79's Avatar
LOL i know i know. hes so pissed he wont even post.
Old Jul 26, 2010 | 09:34 PM
SUKXOST's Avatar
GGGRRRRRR. Too bad I will have the last laugh.
You forgot to mention that not long ago I beat you...yet again....in a freeway pull.....on LOW boost WITH said boost leak.
SUCK ON THAT!
Old Jul 26, 2010 | 09:36 PM
ericgt79's Avatar
little do you know this coupler i already cut small unnoticeable holes in
ecot3c inside's Avatar
ohhhh shittt sonnn!
Old Jul 26, 2010 | 09:54 PM
fakameanrepresent's Avatar
i just did a boost leak test and i too have no leaks.
Old Jul 27, 2010 | 08:32 AM
ei3dag3's Avatar
my maintenance.....
oil - check 99%
boost leak - check
tires - fail
i need tires so bad.
and hey brandon, if i remember right......that one race
Old Jul 27, 2010 | 09:04 AM
umrdyldo's Avatar
Has someone done a How-to on boost leak testing?
Old Jul 27, 2010 | 10:01 AM
SSlobalt's Avatar
I'll try and pump one out this week.
Old Jul 27, 2010 | 10:24 AM
snoftall's Avatar
^^ This would be awesome!
Old Jul 27, 2010 | 11:40 AM
SUKXOST's Avatar
I did the same with your condoms....so wait for a knock on your door in a few months! LOL
Originally Posted by interviewatruins
my maintenance.....
oil - check 99%
boost leak - check
tires - fail
That race was TARNISHED and you know it! LOL
Old Jul 27, 2010 | 11:23 PM
boost leak test is easy, just make your own tester. and put it at the hot side charge pipe. i did not feel safe putting it at the turbo inlet.
Old Jul 27, 2010 | 11:25 PM
mexi_loco's Avatar
oooohhhh...a BOOST leak. Thought you meant brandon had another kind of leak.........
....from his vag
Old Jul 28, 2010 | 09:23 AM
ei3dag3's Avatar
hahaha no one said anything about not brake boosting.
lmao.
i had to one up you with that sick tune, we need to rematch though.
no brake boosting though so we can see what its like with no leaks.
Old Jul 28, 2010 | 06:51 PM
ericgt79's Avatar
lmao.
LOL that race wont be happening any time soon.
Old Jul 28, 2010 | 06:56 PM
DoMiStIc_RuSh_06's Avatar
So when you guys do a boost leak test do you cap off the throttle body.
Old Jul 28, 2010 | 07:15 PM
ericgt79's Avatar
i didnt with the car off the tb should be closed anyway
Old Jul 28, 2010 | 08:23 PM
Ok, I'm gonna try it without capping off the throttle body. Did you have to cap of any of the vacuum lines?
Thanks
Old Jul 28, 2010 | 09:08 PM
ericgt79's Avatar
no just disconnect your tube from the turbo plug in the checker and add air and listen. tighten any loose clamps and recheck
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
