I have a stupid question to ask
Old Jun 10, 2020 | 03:03 PM
themusicguy1989's Avatar
So, I have a 2010 cobalt SS. And I only put 93 in it from Shell, Exxon, or Bp. So I know you want to keep good gas in it. But I live in Wilmington, NC and hurricane season is coming up. And it’s supposed to be bad this year. My power is going to go out 100% possibly for weeks. So I bought a power inverter so I can still use my laptop to get work done. I love how the battery is in the trunk because you can connect and run it straight thru the backseat without doing any surgery.
So my question is will I damage my car if I put 87 in my car and only let it idle? When the power goes out I plan to only use it as a power generator so I’ll basically let it idle until it runs out of gas.
Old Jun 10, 2020 | 03:18 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
No, you should be fine. Anything less than premium only becomes a problem when you throw boost and/or timing at it.
EDIT: I mean you'll be good as far as using 87. I would personally be a bit leery of only idling the car in my driveway for hours at a time.
Old Jun 10, 2020 | 03:51 PM
I agree, idling for hours on end might not be the best for the car. I would go get a cheap generator now, before any hurricanes hit. The small generators will use way less fuel than your car will, you could even get a slightly larger one to run a computer and a window AC unit.
Old Jun 10, 2020 | 07:00 PM
5-Speed's Avatar
Agree with the above. Go to your local Harbor Freight and get one of these. Only $125 and sounds like it will do everything you need it to. Maybe even more.
https://www.harborfreight.com/900-wa...arb-63025.html
ShadowHelper
Feb 22, 2013 04:46 AM
lilskarvcx
Jun 18, 2010 11:49 PM
PinaSS
Dec 19, 2007 12:00 AM
bluebalt
Nov 9, 2006 10:56 PM
