intercooler bracket broke
Old Jul 21, 2010 | 05:10 PM
jaygo7007's Avatar
while parking my car i kinda pull up too far and hit the curb. when i reversed i noticed this little thin bracket or whateva that i guess holds or supports the intercooler was hanging. i wanted to know could i remove this or where could i get another at. thanks
Old Jul 21, 2010 | 05:13 PM
coopercharge's Avatar
more than likely dealer only item.
Old Jul 21, 2010 | 05:14 PM
jaygo7007's Avatar
is it needed to hold the intercooler or could i remove it?
Old Jul 21, 2010 | 05:18 PM
iboost's Avatar
yea you need it. There are two bolts on each side holding the intercooler. Other than that...just the charge pipes are holding it. You can get them from GMpartsdirect.com I believe...
Old Jul 21, 2010 | 05:20 PM
Wangspeed's Avatar
That's not your intercooler bracket. You're talking about the condensation pipe that hangs below the IC. Another one bites the dust. Check your intercooler endtanks. There's a chance they may have cracked.
https://www.cobaltss.net/forums/show....php?p=4878838
Old Jul 21, 2010 | 05:58 PM
jaygo7007's Avatar
thanks for the link. im stuff kinda new to the fi scene so when you say check my intercooler endtanks what am i looking at and for?
i will be ziptieing it tonight
Old Jul 21, 2010 | 06:34 PM
ronn's Avatar
Check this link:
https://www.cobaltss.net/forums/show...2&postcount=41
Old Jul 21, 2010 | 07:52 PM
iboost's Avatar
OHHHH! The little water collector thing. my bad. Yea mine got ripped off. I just plugged the hole and was good to go...
Old Jul 21, 2010 | 08:49 PM
Wangspeed's Avatar
Til you throw codes and can't explain why your car is driving poorly. If you knocked it off, there's a good chance that you either cracked the endtank, or bent a tab. I wouldn't be surprised if your IC was leaking.
Old Jul 22, 2010 | 12:30 AM
jaygo7007's Avatar
so i should just buy a new intercooler
Old Jul 22, 2010 | 07:35 AM
Whitty's Avatar
leak test it first. a lot of guys can either get the IC warrantied for the end tanks cracking, or fix it with jb weld or something similar.
Old Jul 22, 2010 | 08:07 AM
iboost's Avatar
Oh yea...I blasted a big ass hole in it. I threw a code and couldn't boost. I plugged it with JB Weld and pressure tested it. I was good and it held the 23psi
Old Jul 24, 2010 | 11:24 PM
jaygo7007's Avatar
was looking for a intercooler and i ran into this. i know this is to good to be true but would this fix my problem
http://cgi.ebay.com/ebaymotors/FMIC-...Q5fAccessories
i been looking and cant find nothing. found some sweet deals on intercooler piping but i dont really trust ebay
Old Jul 25, 2010 | 04:04 AM
SSlobalt's Avatar
No way to mount it to our car, plus you would had to buy some metal 90 degree elbows to hook up the OEM piping.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
agentirons
Oct 16, 2015 02:11 AM
Delta coupe
Sep 30, 2015 08:11 AM
