Iv never been happier looking at a spring..
no they are putting down MORE whp than you with drivetrain loss... and most of them, that spring is one of the 1st things they do to the car... even a lot of the HHR guys have had good results tuning with it, just the Cobalt that seems to have a problem with flutter with it... i've seen a couple in the 350whp/360ft-lbs on heartbreakers and like I said, they actually have a drive shaft to soak up some power
and I know "no dynos are created equal" and I will agree but the fact is, with drivetrain loss, they should be down a good bit to us
From not very long ago.
What's the highest HP STOCK turbo kappa? Put down 307rwhp - Page 2 - Pontiac Solstice Forum
So please explain your fanciful numbers, and the uber tuners that magically make the Kappa turbo more efficient. I want some of that kool aid.
Anyway like he said, i wouldnt say solstice tuners are better.
and 360 peak torque on stock turbo? Check my dyno sheet in gallery. Monster mods you say? Think again, thanks byt.
Now, did anyone think about the LNF Pontiac has no vacuum canister but ours does. What if we did the canister mod and got rid of that vacuum would it change the result of turbo flutter? Thinking that larger vacuum down the line would create a draw from a BPV. That is trying to close faster than normal?
