K & N intake filter egg shape
Old May 3, 2011 | 11:36 PM
Josh Leverington's Avatar
Typhoon intake air filter oddly shaped. Does it matter how u position it pics are welcomed. Thanks
Old May 3, 2011 | 11:44 PM
BackInBlack's Avatar
Solid metal pleat (should only be one, where the filter is wrapped and meets itself) should be positioned at 12:30 if I remember correctly. Hope that helps.
Old May 3, 2011 | 11:45 PM
TommyP's Avatar
AWD > FWD
Yes it matters. It severely affects how the MAF is skewed. Last I heard, you're supposed to put the thicker side facing up, so the logo will be upside down I think.
Old May 4, 2011 | 12:22 AM
That's what I thought, I have mine kicked off to the side the extra
Meat around 8:00 I now have an engine light :s
Old May 4, 2011 | 08:11 AM
CudaJoe's Avatar
rotate it more upwards. When I checked fuel trims around that position, they were waaaay positive if I remember correctly. You probably exceeded +18.0% LTFT and set a CEL.
Old May 4, 2011 | 08:31 AM
evil 2.0's Avatar
i have mine at about 10 oclock and my ltft are +2.1 check them this morning on the ride home
Old May 4, 2011 | 08:50 AM
Gremlin85's Avatar
Yes, the metal pleate that connects the filter material should be positioned around 12:30 (and the K&N logo on the front will be upside-down).
I, personally, have it set up the complete opposite for looks But I was able to tune my fuel trims to accomodate it that way. Not recommended unless you will be spending A LOT of time fine tuning the fuel trims.
Old May 4, 2011 | 09:04 AM
RoadconeTuning's Avatar
anyone tried to just run a normal cone filter?
Old May 4, 2011 | 09:38 AM
Okay! So small k & n logo on the back of the air filter position that at the 12:30 position?!!
Old May 4, 2011 | 10:11 AM
robk's Avatar
Damn someone read my mind this morning, lol. As i just installed my typhoon lastnight along w my FORGE bpv!!! Thanks for the thread
rpbk
Old May 4, 2011 | 10:16 AM
TommyP's Avatar
AWD > FWD
Skewed fuel trims are why I'm doing dual interceptors before I do my intake.
Old May 4, 2011 | 10:19 AM
robk's Avatar
Im tuned currently but obviously not for the typhoon, but i will be this weekend at our dyno day. So im not worried bout it, lol. Ill check the trims on the DH on the way home on mine
robk
Old May 4, 2011 | 01:20 PM
xray_racer's Avatar
I can't seem to get my fuel trims below +13 with the K&N. They were at +2 with the stock intake. I've tried rotating the filter to almost every position and it doesn't seem to matter. I'm planning on getting a retune hopefully soon.
Old May 4, 2011 | 01:24 PM
Dart_SI's Avatar
got mine at 11 o clock. im tuned for it also tho.
Old May 4, 2011 | 01:30 PM
Gremlin85's Avatar
You got the intake after you were initially tuned by Trifecta?
That is most likely why it skewed so much. What I've read and experienced myself is, installing the Typhoon intake on a completely stock balt doesn't skew the trims so much when the filter is positioned to 12:30 (The metal pleat in the filter). BUT, if you've been tuned with the stock box or even another intake, rotating the filter will do nothing to help your trims. It's been tuned specifically for your previous setup and will need to be retuned again.
Again, this is just what I've experienced and read.
Old May 4, 2011 | 01:48 PM
arizbea's Avatar
I asked Vince @Trifecta about this and he claims I shouldn't need a re-tune unless I feel it not running right. I have no way to check my fuel trims so I guess I won't know unless I feel it running rough.
Old May 4, 2011 | 03:18 PM
xray_racer's Avatar
Yeah, I was already Trifecta tuned. I wouldn't be that worried about it, but I am getting some knock. Not very often, but still getting some. Maybe it's because the best gas around here is 91 octane. I'm just going to retune to make sure it's all good. It's worth it.
Old May 4, 2011 | 03:19 PM
xray_racer's Avatar
It probably won't hurt anything, but I don't like to trust "probably".
Old May 4, 2011 | 03:31 PM
Gremlin85's Avatar
The fuel trims are gonna go out at least a little bit no matter what. It'll be fine unless they are WAY out.
That's my thinking. It's always worth it
And again, that's my thinking.
Old May 5, 2011 | 11:31 AM
robk's Avatar
Watched mine lastnight as well as this morning, currently LTFT's are sittin around +8.6 give or take. Dont seem to be running bad at all . Ive only got one complaint about this setup, and thats i cant keep my foot outta her!!!
robk
Old May 5, 2011 | 11:54 AM
Gremlin85's Avatar
robk
Haha, it's so addicting to hear that wooosh and pssshhh!
What are you using to watch them? Personally, (and this is just my opinion again), I wouldn't want my LTFT's to be outside of +/-4. But I am a bit of an **** OCD perfectionist and I keep mine within +/-1.8 lol.
Old May 5, 2011 | 01:20 PM
ManTFresh's Avatar
dont mean to thread jack but, i have a zzp charge pipe and catless downpipe. i am wanting to purchase the K&N SRI but dont know how much it will effect my ltft/stft with out gettin a tune. i guess my ? is, is this a good idea to do or not???
Old May 5, 2011 | 02:05 PM
PrincessTurbo's Avatar
I've been hearing that story a lot lately ..
Old May 5, 2011 | 02:29 PM
CudaJoe's Avatar
you'll be fine it you position the filter the right way
Old May 5, 2011 | 03:07 PM
robk's Avatar
Uhh yea it is, lol. Ive got MSD Dashhawk tht im using. Im not to worried bout my trims, getting a retune this sat on the dyno. Hence why i had to get it on this week, lol
robk
