K&N Intake for SS/TC
Old May 21, 2010 | 02:53 PM
  #301
cmiller8006's Avatar
I sent them an email, awaiting response.
Old May 21, 2010 | 03:24 PM
  #302
hunter19707's Avatar
Interesting, have not looked at mine yet.
Old May 21, 2010 | 03:29 PM
  #303
Gimpster's Avatar
In hindsight it might be a really good thing K&N only made 30 kits for now. Imagine if they had to go back and open up 500 to put a different bracket or supplement the original one?
Either way I'm amused that an intake people have been waiting 6-7 MONTHS for, 17 pages of forum babble and this happens. In the grand scheme of things not a big deal, but just kinda amusing all around.
Old May 21, 2010 | 03:38 PM
  #304
Rissa's Avatar
I'll look at mine when I get home to see if it has those.
Old May 21, 2010 | 03:51 PM
  #305
HB_SS/TC's Avatar
Why me? lol
at least it doesn't surge or stutter like the AEM does
Old May 21, 2010 | 03:54 PM
  #306
RYRO14's Avatar
Mine doesnt have them either.
Old May 21, 2010 | 04:14 PM
  #307
skuruc's Avatar
I just checked my 09 doesnt have it
Old May 21, 2010 | 04:18 PM
  #308
irocjr's Avatar
I just ran out and checked. My '10 has the plate and the bolts.
Old May 21, 2010 | 04:20 PM
  #309
HB_SS/TC's Avatar
Pics
Old May 21, 2010 | 04:39 PM
  #310
BLAZIN07SS's Avatar
I'm too JDM for you
does it move around a lot without that bracket there?
Old May 21, 2010 | 04:40 PM
  #311
SSLOW's Avatar
haha, the dryflow looks like it belongs in there better than the cone
Old May 21, 2010 | 04:42 PM
  #312
HB_SS/TC's Avatar
I wouldn't say A LOT but it does move a little.
It makes the BPV sound like kicking a sick dog lol
My car will be dropped off at k&n on Monday so they'll fix it
Old May 21, 2010 | 05:00 PM
  #313
rukkee's Avatar
My 09 has the bolts ..... There was a bunch of production updates done to the cobalt in the early spring of 09..... sometime in febuary IIRC...... They added the fuel pump sound deading ...fix an oil leak and a few other minor revisions..... I wonder if thats when that plate was done? USB became standard .... no SS symbols on the dash piece .....ect ect. FWIW my car was built 4-17-09
I think it was right around the times in this bullietin
#09-07-29-003: Transmission Fluid Leak, Slipping Clutch or Broken Axle Shaft (Replace Trans Assembly/Front/Rear Mounts and Both Axle Shafts-Contact District Svc Mgr (Warranty Mgr in Canada) for Repair Approval) - (Jun 12, 2009)
Subject: Transmission Fluid Leak Due to Clutch Housing Fatigue, Slipping Clutch or Broken Axle Shaft (Contact District Service Manager/Warranty Manager (in Canada) for Repair Approval)
Models: 2005-2009 Chevrolet Cobalt SS
2008-2009 Chevrolet HHR SS
2004-2007 Saturn ION Redline
Equipped with 5-Speed Manual Transmission (RPO MU3)
Built Prior to February 12, 2009 (Lordstown) or February 26, 2009 (Ramos)
Attention: Be advised that failures of this nature are generally caused by customer abuse. They are NOT defects in materials or workmanship for which General Motors would be responsible for and should not be covered under the terms of the new vehicle warranty. Vehicles with this complaint should be inspected by your service manager and District Service Manager (Warranty Manager in Canada). A field product report should be submitted on each case. Also, if aftermarket kits are added that may effect the driveline loads, the transmission would not be warranted.
Condition
Some customers may comment about a slipping clutch. Upon further investigation, the technician will find transmission oil in the clutch housing.
Cause
This condition may be caused by excessive front wheel hop during wide open throttle (WOT) acceleration events. Excessive wheel hop transmits a torsional shock load into the transmission case. This may cause the transmission case to fracture (as shown in graphic below) and transmission fluid to leak into the clutch housing.
Correction
Important: Prior to any work being performed, contact your District Service Manager/Warranty Manager for repair approval.
For 2005-2007 Chevrolet Cobalt SS and 2004-2007 Saturn ION Redline
If this repair is approved by the District Service Manager/Warranty Manager, replace the transmission assembly. During removal of the transmission, replace the front (GM P/N 20814994) and rear (GM P/N 20814995) powertrain mounts. Refer to SI for the procedures on replacing the transmission front and rear mounts.
For 2008-2009 Chevrolet Cobalt SS and 2008-2009 Chevrolet HHR SS
If this repair is approved by the District Service Manager/Warranty Manager, replace the transmission assembly. During removal of the transmission, inspect the following parts and replace if necessary (excluding tires):
• Tire wear (excessive or uneven) front vs. rear or rubber debris in the front wheel house liner area.
• Inspect the upper right side mount for fluid leaks or (rubber) structural failure.
• Front and rear powertrain mounts, if necessary (refer to SI for the procedure on replacing the transmission front and rear mounts).
Important: Verify that the 12-volt battery has a battery charge of 12 to 16 volts. The battery must be able to maintain a charge during programming. Only use approved Midtronics 165-PCS charger or equivalent to maintain proper battery voltage during programming. The J 2534 MDI will reprogram the modules in less time than the Tech 2Ž scan tool.
Reprogram the ABS with a updated service calibration using the TIS2WEB Service Programming System (SPS) application. Make sure your Tech 2Ž is updated with the latest software version. The ABS calibration is available to dealerships in TIS2WEB (website version of TIS). Refer to Electronic Brake and/or Traction Control Module Reprogramming with SPS procedure in SI.
Install Clutch Actuator Pipe Elbow Assembly (P/N 24252286)
•Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection.
•Remove the cover from the underhood electrical center.
•Remove the underhood electrical center bracket from the vehicle and reposition the electrical center (1) to access the bracket. Refer to Underhood Electrical Center or Junction Block Bracket Replacement.
Note: Rotate the hose to stop brake fluid from running out of it.
•Disconnect the hydraulic clutch hose (3) from the clutch actuator cylinder (2) and the clutch master cylinder (1).
•Install the clutch actuator pipe elbow assembly, GM P/N 24252286.
•Connect the hydraulic clutch hose (3) to the clutch actuator cylinder (2).
•Bleed the clutch hydraulic system. Refer to Hydraulic Clutch Bleeding.
•Install the underhood electrical center bracket to the vehicle and install the electrical center into position on the bracket. Refer to Underhood Electrical Center or Junction Block Bracket Replacement.
•Connect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection.
Parts Information
Part Number
Description
Qty
24252286
Elbow Asm - Clu Actr Cyl Pipe
(Front) Transmission Mount
(Rear) Transmission Mount
Warranty Information
Use labor operation and time that is approved by the District Service Manager/Warranty Manager.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Š 2010 General Motors. All rights reserved.
Old May 22, 2010 | 12:20 AM
  #314
soundjunky's Avatar
<removed to shorten quote>
here I was thinking that people were adding it to their dash!?
Old May 22, 2010 | 12:53 AM
  #315
jarhead's Avatar
I believe you are right rukkee, My very early april 08 does not have the bolts either just checked. Most likely added in spring 09 I bet no 08s and earlier fall 08/winter built 09's do not have the bolts either.
Old May 22, 2010 | 01:05 AM
  #316
Yep, mine doesn't have 'em either.
Old May 22, 2010 | 09:29 AM
  #317
CudaJoe's Avatar
1. Supercharged Guy (Now)
2. DoMiStIc_RuSh_06 (Not Sure)
3. Gimpster (Now)
4. Ford (Now)
5. RYRO14(If it works right)
6. cmiller8006 (Now) (as long as its under 300 shipped)
7. hunter19707 ^^^^^this^^^^^
8. CudaJoe (I want it now!) also this ^
Old May 22, 2010 | 09:47 AM
  #318
SC cobaltss15's Avatar
how much is this thing?
Old May 22, 2010 | 10:01 AM
  #319
CudaJoe's Avatar
its says $306.xx on the website. I wouldnt mind getting it less than $300 shipped though.
Old May 22, 2010 | 11:13 AM
  #320
jphugel11's Avatar
3. Gimpster (Now)
4. Ford (Now)
9. jphugel11(if the price is right!)
AT LEAST ONE MORE PERSON!! THAT WOULD MAKE 10!
Old May 22, 2010 | 11:56 AM
  #321
Gestapo007's Avatar
whats that thing welded on it post maf and b4 CCV
Old May 22, 2010 | 11:58 AM
  #322
HB_SS/TC's Avatar
It bolts to the bracket so the intake won't move.
Old May 22, 2010 | 12:40 PM
  #323
jphugel11's Avatar
^do you only have the option of the oiled filter or can you get a dry filter for it also?
Old May 22, 2010 | 12:46 PM
  #324
I believe that dry filter is an AEM. HB SS/TC said it ran better with the K&N.
Old May 22, 2010 | 12:54 PM
  #325
jarhead's Avatar
Originally Posted by HB_SS/TC
Oh I made sure they were aware lol
again I'm taking my car to k&n on Monday so they can get it fixed
K&N has quite the machine fab shop just watched an episode of overhaulin last night that used there shop and talent to do a 63 falcon.
