KO4r Upgrade?
Old Aug 15, 2016 | 03:59 PM
userperzz's Avatar
KO4r Upgrade?
Would there be a big difference using the K04r over the stock K04?
Looking for quick bolt on upgrades.
Old Aug 15, 2016 | 05:01 PM
With e85 or and meth yes it's worth it for the price
Old Aug 15, 2016 | 06:13 PM
userperzz's Avatar
What about without E85? We don't have it available anywhere around here.
I know adding a DP and exhaust will be first but want other quick bolt on ideas.. not looking to make Crazy HP.
Old Aug 15, 2016 | 06:17 PM
On 91 it isn't that worth it tbh
Old Aug 15, 2016 | 09:17 PM
Sl0wbaltSS's Avatar
K04r With E85!
Old Aug 15, 2016 | 09:57 PM
Ritzard's Avatar
How is the k04r different then k04? Is this just a compressor wheel upgrade?
Old Aug 16, 2016 | 09:10 AM
CudaJoe's Avatar
k04r is a bigger compressor wheel, I looked up the specs of a bunch of turbos to compare it too. I'll see if I can find them.
Old Aug 16, 2016 | 09:15 AM
CudaJoe's Avatar
Originally Posted by CudaJoe
basically from what Ive seen
LNF K04 factory________has a 43mm Inducer_____56mm Exducer________price varies..________32-34? Ib/min
Werksracing WR-1 K04+__has a 46.5mm Inducer___60mm Exducer________$1250, direct bolt on_____38.4 Ib/min
BNR GT2860 ___________ has a 47.3mm Inducer___60mm Exducer_______$950, direct bolt on______38 Ib/min
K04R__________________has a 50mm Inducer____65.9mm Exducer ______$495, direct bolt on______???
Hahn super20G kit_______has a 52.6mm Inducer___68mm Exducer________$1199, need BOV_____43 Ib/min
BNR GT2871___________has a 53.2mm Inducer____71mm Exducer________$1200, need BOV_____???Ib/min
ZZP ZFR 6758__________has a 54mm Inducer______67mm Exducer_______$1940, direct bolt on____49Ib/min
ZZP S256 kit___________has a 56mm Inducer______80mm Exducer_______$3100, need BOV______58 Ib/min
ZZP ZFR 7163__________has a 57mm Inducer______71mm Exducer_______$2240, direct bolt on____60 Ib/min
ZZP S259 kit___________has a 59mm Inducer______80mm Exducer_______$3300, need BOV______62 Ib/min
Those are the turbo options that I know of.
So from that you can see that the inducer part of the compressor wheel is 4mm bigger while the exducer is 10 mm bigger. Basically the compressor is 10mm wider than factory k04. Theoretically it should make more power than the BNR 2860 but I dont think thats the case.
Old Aug 16, 2016 | 09:40 AM
userperzz's Avatar
So the K04R wouldn't be worth it if I am running 93? Wish we had E here...
Old Aug 16, 2016 | 09:44 AM
Meth will help you alot but 93 is still better than 91
Old Aug 16, 2016 | 09:49 AM
CudaJoe's Avatar
20g would be the cheapest real power you can make. ~400whp with a good tune and pump gas. or just below it. I think its safer than the zfr as well. Alot of people losing their trans with the zfr and no boost ramp.
Old Aug 16, 2016 | 10:27 AM
hawkssoccer11's Avatar
if you get the K04r its nice for the price. it will hold boost all the way to redline where as the stock k04 wont do that and starts to fall off. you will be able to make around 350-360whp on 93 so not much more then stock turbo on e85 but like they said meth will help out big time.
Old Aug 16, 2016 | 10:29 AM
63 Nova SS's Avatar
20 g also spools higher than a zfr so your not gonna have a torque hit like you would without much boost ramp on a zfr
Joe- I have seen my + go as high as 39.2 since going with a catless dp, but it usually is running 38.4 in 3rd and 4th gear in wot.
Also the compressor outside dimensions for the r + and stocker are the same. I believe they mill the inside of the housing for the wheel to fit.
Old Aug 16, 2016 | 11:44 AM
CudaJoe's Avatar
okay, the figures I got were from each companies website information on their turbos. The 38.4 came from you
Old Aug 16, 2016 | 12:45 PM
userperzz's Avatar
This is all great info! I think 350 - 360 would be good for us right now. I am liking the fact that the K04r doesn't fall off like the stock one does.
Keep the stock BPV?
Old Aug 16, 2016 | 01:08 PM
Keep the stock BPV?
you can keep the stock bpv but if you want go head and get the Forge BPV you wont be dissapointed thats for sure. also if you get the R make sure you get the boost acuator, let Matt know at turbo bay when you order or it may even be an option when you order too.
Old Aug 16, 2016 | 01:37 PM
cluelessk's Avatar
I remember people having issues with forge bpv's. Was that a trifecta tuning issue or has it a all been sorted?
Old Aug 16, 2016 | 02:40 PM
That idk. i know i never had any issues with mine and that was one of the first mods i did haha. so that was on my car for about 4-5 years lol. i know people have an issue with the springs sticking, which i would take mine apart and clean it once a year to get all the gunk and **** out of it.
Old Aug 16, 2016 | 02:43 PM
I have the Forge with my R and haven't had a problem
Old Aug 16, 2016 | 05:47 PM
63 Nova SS's Avatar
Stocker does a good job and I wouldn't spend the money but that's just me.
king_balt17
Aug 17, 2016 08:36 AM
Staged07SS
13
Aug 12, 2016 07:13 AM
genosis8703
Aug 10, 2016 07:24 PM
thewafflesareburnt
Aug 8, 2016 09:54 PM
CaRRiED
Jul 29, 2016 04:39 AM
