long term maintenance?
Old Nov 2, 2010 | 02:50 PM
msfitoy's Avatar
Hey guys...my 09 just got it's recall for the steering pump warranty so I'm scheduling an appointment...my question is that this daily driver of mine just hit 60k so I'm planning on having a radiator flush as well as trans fluid refresh...anything else I should have the dealership look at while I'm there? Frankly, I'm amazed that I've had practically zero issues with this car since new and pushing 23psi Trifecta tune...well other than I know I'm needing a stronger clutch next year lol...
Old Nov 2, 2010 | 03:27 PM
Yellow09LNF's Avatar
dex cool is good for 150k, don't worry about the coolant this soon, if you haven't done spark plugs yet get some step cooler plugs( i got the ngk's from mpx) the lnf eats plugs.
Old Nov 2, 2010 | 03:30 PM
ssweeet's Avatar
Sub'd for future reference.
Old Nov 2, 2010 | 03:36 PM
msfitoy's Avatar
lol...I know about the plug lnf appetite...
Old Nov 2, 2010 | 04:01 PM
yeah, i'm at 19k and on my thrid set, the ngk's let me run a little more timing aswell
Old Nov 2, 2010 | 04:23 PM
ronn's Avatar
I have 15K on my car now (bought at 8K mi already tuned) with NO ISSUES. I assume original stock plugs are on the car and that's what I intend to replace them with at 30K miles.
Old Nov 3, 2010 | 08:58 AM
wantedSS/TC's Avatar
When tuned the plugs will last 10k. Log your car and see what I'm talking about. It takes considerable more knock to actually show up on the RPD.
HPT log showed 6* and RPD only showed 1* at the same time. Has been consistently the same. Plugs take 10 minutes to change. If tuned, do it every 10k. Preventative maintenance to be safe than sorry.
Old Nov 3, 2010 | 02:47 PM
ronn's Avatar
I just logged my car (HPT) and posted results here. There was absolutley ZERO knock. The log has WOT runs from 60-100MPH. Again plugs are ORIGINAL with over 14K mi on them.
Old Nov 3, 2010 | 02:51 PM
Iam Broke's Avatar
What about misfires? Any mor ethan a few logged means you need new ones soon. Trust me.
Old Nov 3, 2010 | 04:01 PM
ronn's Avatar
My logs didn't show any as far as I know..at least it wasn't pointed out by the tuner doing the logging. If you have significant misfire won't it throw a code?
P0300 Engine Misfire Detected ECM, PCM
Old Nov 3, 2010 | 04:18 PM
Iam Broke's Avatar
Not until you have a bunch in a row. You'd be surprised how many misfires are logged in a normal commute.
Old Nov 4, 2010 | 12:00 AM
ronn's Avatar
Found this old post. Shows plugs with 20K on em. Except for being dusted with carbon deposits, the electrodes are not fouled at all.
https://www.cobaltss.net/forums/2-0l...-plugs-202683/
The car has been tuned for 15k out of its 20k mileage
Old Nov 4, 2010 | 09:01 AM
Depends on tune and how much timing you're throwing at it basically.
Trust me, I'd rather be safe than sorry and change them every 10k if tuned. Mine did NOT look like the picture above and had 5k less on them. What's $25 worth of plugs every 10k anyway? And as I am broke said, misfires happen quite often and it takes several in a row for a code to show.
Old Nov 4, 2010 | 12:36 PM
i was on gm stage 1 fand the porcelain was starting to brown a good distance up the plug, plus after changing the plugs(stock to stock) i noticed the performance difference. I'd rather over change my plugs then play the misfire game lnf's like to play. Plus is your tuning get the ngk step colder, i got to run extra timing because of them.
Old Nov 4, 2010 | 03:28 PM
ronn's Avatar
I ordered stock plugs and will gap em a tad tighter. I know some people have gone next colder range...but I saw a couple posts where they problems with them. They will foul easier than stockers. Not sayin colder range is a problem, just that I don't need em with my tune. As they say, if it ain't broke..... Gonna wait a little longer before I replace em though.
Old Nov 4, 2010 | 07:25 PM
tom.g's Avatar
Like has been said I don't think you need to flush your coolant but it would probably be a good idea to have your brake system flushed (or do it yourself) as well especially if you drive your car like it was meant to be driven.
Change the plugs yourself it takes 10 minutes and you can save a bunch of money and it is worth it.
Also a lot of guys recommend replacing the front O2 Sensor when tuned.
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
Tupp
Sep 30, 2015 08:18 PM
importkiller
Sep 30, 2015 07:18 PM
z28addiction
Sep 28, 2015 12:03 AM
