Looking for GT2860R dyno results on LNF
Old Aug 20, 2015 | 07:18 PM
TurboWood's Avatar
Hi Gents,
I'm in the process of selecting my turbo (stock turbo + manifold doesn't fit in the car) and wanted to get a representative dyno from the GT2860R. From what I've read it's close to the stock turbo, but I was still hoping to get a dyno so I could have a baseline. Please specify the turbine A/R used if possible.
Thanks,
Daniel
Old Aug 21, 2015 | 01:55 AM
kzak104's Avatar
i have a gt2871r havent dynoed yet, im running 25psi, spools pretty quick, not as fast as stock tho. i have a .63 ar turbine housing.
Old Aug 21, 2015 | 09:14 PM
tomj77's Avatar
Originally Posted by TurboWood
Hi Gents,
Thanks,
Daniel
What car is it going into
Old Aug 21, 2015 | 09:38 PM
TurboWood's Avatar
Caterham 7
Old Aug 22, 2015 | 01:47 PM
tomj77's Avatar
To bad u can't fit lnf with zfr in there, that be one fast car. But if it was me, I'd make it fit. There is always a way lol
Old Aug 22, 2015 | 08:50 PM
TurboWood's Avatar
I have significant cooling system and torque limits (from the transmission). I'm going to be in trouble trying to reject enough heat to sustain 300hp and the transmission is limited to 300ft*lbs. It should be enough for a 1300lb car though .
Old Aug 22, 2015 | 10:27 PM
nathan112i's Avatar
with that many limitations perhaps you should look into a big wheel k04 such sas the k04R from turbobay performace, i had one on my car and loved it until i went big turbo
Old Aug 22, 2015 | 10:59 PM
Sharkey's Avatar
what transmission are you running?
Old Aug 23, 2015 | 08:21 AM
TurboWood's Avatar
modified Ford Type 9
Old Aug 23, 2015 | 07:59 PM
Sharkey's Avatar
ok i see how your limited then. cant say that would be my first choice of gearbox. myself, i would have elected to use a close ratio world class t5. they can take 350-400ft/lb in a 3200lb car, be near indestructable with a 4 cylinder in something as light as a super 7
Old Aug 24, 2015 | 03:55 AM
TurboWood's Avatar
The T9 wasn't so much a choice. It is what Caterham recommends (read: drive-shaft and trans mount setup for it) and it's really the only thing that will fit. The transmission tunnel is tiny. I had to machine flats in the drive-shaft output flange so that it would fit through the tunnel. The T9 is also very light (74lbs).
Besides, I hope Bugatti power to weight is enough to keep me happy for a while.
Daniel
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
maliki778
Oct 1, 2015 07:39 PM
patooyee
Oct 1, 2015 01:07 PM
