low fuel pressure help
Old May 17, 2013 | 03:24 PM
VCCss/tc's Avatar
Ok guys...seen threads like mine before but nobody really says anything besides hpfp. I'm getting code P0087. Replaced the hpfp...and I still have the code. Any help would be amazing. Thanks
Old May 17, 2013 | 09:10 PM
Nfamous60's Avatar
You check the fuel rail pressure sensor?
Make sure the lobe is hitting the roller ?
My case was crazy I had a high spot where the roller hits the fuel pump so it was getting stuck replaced that now I'm gud to go.
If u replaced the pump it's sumtin mechanical, Wut caused the code? Like Wut were you doing when it happened.
Old May 19, 2013 | 04:19 PM
TurbaltSS_09's Avatar
Could maybe be fule pump? maybe you need a high pressure fule pump? good luck
Old May 19, 2013 | 05:50 PM
Knight's Avatar
I need help with this also, my car is giving me a low fuel pressure code too and I'm driving around in "ENG PWR REDUCED" mode. I went through the whole hassle/learning experience after buying a fuel filter and trying to find it that it is unserviceable and integrated with the fuel pump. I guess my next course of action is just to take it to a shop and have someone change out the pump for me unless there is a known fix for this. I've heard rumors that the fuel pump is under recall, is this true for 08+ SS's?
Old May 19, 2013 | 05:56 PM
iameric's Avatar
its either a faulty fuel pressure sensor, worn cam lobe or the injectors. the reason why that code is set is because your fuel pressure is 218psi lower than desired, did you look at the hpfp's lobe on the cam when replacing it?
Old May 19, 2013 | 05:58 PM
iameric's Avatar
recall is for a leaking fuel pump at the back of the car, for all cobalts except for the 2010's
Old May 20, 2013 | 06:39 PM
VCCss/tc's Avatar
Somehow a nut got sucked in thru the intake and held a valve open. So I pulled the intake mani off and pilled it out. Rocker popped off the spring but I put it back in and it looked fine. Put thre mani back on and hooked everything back up. Started up first time got p0087.
Old May 20, 2013 | 06:42 PM
VCCss/tc's Avatar
Pressure right before hpfp is at 78 psi idle. Some I'm assuming its not much higher after it.
Old May 20, 2013 | 06:53 PM
09CobaltSS1's Avatar
You assume incorrectly.
Rail pressure at idle oscillates between 407-570psi stock and tank supply pressure is 60-65psi I believe.
Old May 20, 2013 | 07:19 PM
VCCss/tc's Avatar
Ok...where can I check pressure after the hpfp? I checked in on the bezel by the regulater or whatever it is.. the round **** that's bolted to the manifold
Old May 20, 2013 | 08:10 PM
I assume you're talking about the schrader valve. That's only going to give you tank pressure before the hpfp. There actually is no schrader valve on the rail because it would quite honestly blow apart with the pressures that go through the fuel rail. The only real way (that I'm aware of at the moment) to test fuel pressure at the rail is via logging software.
Old May 22, 2013 | 04:14 PM
VCCss/tc's Avatar
So logging software. Is there any besides hpt?
Old May 22, 2013 | 04:44 PM
Sox-Fan's Avatar
Got Brakes?
torque app for an Android with a bluetooth adapter *MIGHT* have the pid for it.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
