My SS sounds like Zoidberg...
Surge is not always caused by damaged fins. Surge is the back flow of air agaisnt the normal flow. Which a destroyed fin could cause surge that would require something to impact the blades which at that point you have more issues than just surge
That's the sound of ur bpv not opening. Check the hoses connected to bpv, check bpv solenoid, remove hose that goes from solenoid to bpv on the solenoid end and run directly to intake manifold. The small hose on the top of intake manifold, disconnect that one and plug the bpv hose in there. This will completely bypass vac tank and solenoid. If it works proper after that, issue is either solenoid or vac tank. Try this and post results
Well u don't want to leave it like that. To bypass valve solonoid is used by the ecu to protect the motor from over boost. I shall comment later to let u know how to bypass vac tank. But now let's find out if it's the solonoid or the vac tank. I totally removed my vac tank, show u how to do it later with the hookups. Gotta goto car and take picture
DANRICKARD
10-01-2015 12:08 AM
