n00b question: how do I read the dipstick?
Old 11-20-2009, 01:24 AM
JT-KGY's Avatar
I cant seem to figure out how to read the dipstick on this car...
Most cars' dipsticks are marked clearly where max and mins levels are....
On the SS/TC.. it goes like..
top of the stick with handle <=== |xxx| | | |xxx|
where's the max? the "|" at the top of the 3 smooth areas? or at the top of the "xxx" area?
Thanks...
Old 11-20-2009, 06:55 AM
Cobalt_Daddy's Avatar
it's much easier to just drain your oil and measure it with your measuring cups. should take 6 liters. haha no no but seriously i'm pretty sure it should be near or on the line but i'd say the x's are a good buffer zone. i've heard people say oil doesn't even show up on the dipstick until you add the 6th litre.
Old 11-20-2009, 07:06 AM
JT-KGY's Avatar
yes.. usually the amount of oil to go from min to max is roughly a quart (for most cars)...
wait.. i put in roughly 5 quarts for the car.. no idea how many liters...
Old 11-20-2009, 10:01 AM
Permafried-'s Avatar
5 quarts = 4.78 Litres
Old 11-20-2009, 11:26 AM
SSlobalt's Avatar
Old 11-21-2009, 09:35 AM
Koz
Koz's Avatar
The owners manual says 5 quarts, does it not? That's how much I put in, and my oil goes up into the top xxxx section.
I think that's where you want it, somewhere in that top xxx zone.
Old 11-21-2009, 09:44 AM
drewbroo's Avatar
I usually do 5 quarts, and top it off with a tiny bit from a 6th quart after the oil settles.
Old 11-23-2009, 06:55 AM
More_Torque_More_HP's Avatar
Thanks...
Here is the quote from the design engineer:
if oil is in crosshatch zone (upper portion) = "FULL" or OK
if oil is in lower crosshatch then you are low and need to add about 1 qt.
We put in the "area" rather than a line due to complaints that reading was not "exact" so we gave "ADD" and "FULL" zones to account for some of the variation....
Old 11-23-2009, 07:07 AM
JT-KGY's Avatar
THANK YOU!!!!!
I just wish that the user's manual explained it as well as you did...
Old 11-25-2009, 02:46 AM
Joemann892's Avatar
I just buy the 5.218 quart container for about 19.99 to 29.99 depending on the deal.
DarrenGC
12-24-2021 01:55 PM
RaginChopsuey
10-27-2015 01:27 PM
Tupp
09-30-2015 08:18 PM
dennis69
09-28-2015 02:16 PM
SlowSaturn
09-28-2015 11:03 AM
Quick Reply: n00b question: how do I read the dipstick?
