need to be a bit faster
Old Jun 28, 2010 | 05:03 PM
  #51
unijabnx2000's Avatar
I think it has to do more with the air flow of the turbo then the amount of boost it can create
Old Jun 28, 2010 | 05:06 PM
  #52
user 70823082's Avatar
Yea but if there isnt enough pressure to go into the IC then not enough will come out which will cause you to lose pressure right?
Old Jun 28, 2010 | 05:13 PM
  #53
(as long as there are no leaks) the turbo is reaching a point where it cant flow anymore air (choke point, right line of a compressor map)
and if your losing more than 1-2 psi from the turbo to the TB then you need to go look for leaks.
Old Jun 28, 2010 | 05:18 PM
  #54
Ok cool. I mean I was just stating what I learned but there always room for more knowledge about these cars lol.
Old Jun 28, 2010 | 05:27 PM
  #55
beast10007's Avatar
My boost falls from 24 to 20 then at 6,000 to 6,8000 it falls to 16 but my HP is still at 300
thats on HP the boost guage in the car shows it at 25-26 and stays at 20 the rest of the way.
Old Jun 28, 2010 | 05:46 PM
  #56
gtsr100's Avatar
i got a 25 one and mine will hold for a sec or 2 then drops down to 22 or 23 then drops more once i get in to the upper rpm not sure what it falls to pay attention to the road and my shifting. i do think i need to data log for him just so i can get a summer tune more so for the humidity
Old Jun 28, 2010 | 07:13 PM
  #57
Supercharged Guy's Avatar
Originally Posted by Terminator2
Even if you weld the WG shut it will not hold 22 psi past 6200 or so. What RPM does it drop to 20 psi.
I can't really pinpoint when it drops but I know it spikes 23.5 for a split second and then quickly falls right to 20.3 to 21. something
I just got in touch with zzp and I'm getting one without the bov flange on it so I should be better off cause I think I had a slight leak
DarrenGC
Dec 24, 2021 01:55 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
