Need new cluitch
Old Apr 3, 2018 | 12:55 PM
RayneLeaf's Avatar
Need new cluitch
Hey guys, I need a new clutch. I am currently bone stock with a CAI but plan on getting a dp amd a tune in the future.
What clutch should I get?
I'm on a budget and I currently have about 400 to spend.
Thanks for your time
Old Apr 3, 2018 | 01:01 PM
exninja's Avatar
Stock will do you just fine.
Old Apr 3, 2018 | 01:06 PM
RayneLeaf's Avatar
Sorry to ask but would you mind posting a link for one? I don't know much about clutches as I've never had to buy one before. Most I'm finding seem sketchy..
Old Apr 3, 2018 | 01:15 PM
exninja's Avatar
Cobalt - HHR LNF Clutch Kit 24239996K
At a minimum, you will also need flywheel bolts and the flywheel resurfaced. GM says not to resurface, but as long as your machinist is not a buffoon and takes too much off then you should be ok (also need to remove an equal amount of the step where the pressure plate attaches). The safe bet is a new flywheel. Tdubbs has had good success with this one:
LNF Flyheel LNF Flyheel
He has a thread on here with his experience: https://www.cobaltss.net/forums/drivetrain-79/luk-flywheel-updates-323062/
I resurfaced mine with zero issues, some have resurfaced and blamed a failed slave cylinder on that. I also only had 71k miles when I did it and the clutch appeared to have minimal wear. A flywheel resurface should remove a very minimal amount of material; you're just roughing the surface to provide a new surface for the new clutch to bed in. If you've had 200k+ miles on it, there may be too much material gone on the flywheel. The slave cylinders are particular to travel length and overextension will do bad things.
Old Apr 3, 2018 | 01:21 PM
RayneLeaf's Avatar
At a minimum, you will also need flywheel bolts and the flywheel resurfaced. GM says not to resurface, but as long as your machinist is not a buffoon and takes too much off then you should be ok (also need to remove an equal amount of the step where the pressure plate attaches). The safe bet is a new flywheel. Tdubbs has had good success with this one: LNF Flyheel He has a thread on here with his experience: Tdubbs flywheel thread
Thank you so much, I'll look into that. One thing though, the Amazon link you posted didn't work.
I also came across this on this site. Thoughts?
Amazon Amazon
edit: Nevermind what i said about the link not working
Old Apr 3, 2018 | 01:23 PM
exninja's Avatar
Try the link again.
The one you posted appears to be for a base Cobalt. That will not work for an SS.
Old Apr 3, 2018 | 01:27 PM
exninja's Avatar
I googled the part numbers for the clutch parts and bought them on one or two dealership websites. OEM will hold the power you need and is plug-and-play. There are some "performance" aftermarket clutches, but some have not had good success working with other parts (overextension, etc.). If you're going to be over 350hp then I'd look into that stuff, but with those mods you're not going to get to that point.
Old Apr 3, 2018 | 01:34 PM
RayneLeaf's Avatar
Thank you again, I'll go with the clutch you posted. I have 111k miles on my car. All I need is this kit and flywheel bolts and I'm set?
Old Apr 3, 2018 | 01:49 PM
exninja's Avatar
pretty much, and fluid
Old Apr 3, 2018 | 02:38 PM
You def want a new flywheel, they're not that expensive (in relative terms) compared to destroying a clutch.
https://zzperformance.com/ecotec/tra...-flywheel.html
Old Apr 3, 2018 | 04:18 PM
user 72239's Avatar
Yeah just get a new flywheel. Don't resurface the old one
Old Apr 3, 2018 | 05:58 PM
63 Nova SS's Avatar
Do we have a stickie for clutches? Wouldn't hurt, then we could just point people there.
Old Apr 3, 2018 | 08:31 PM
RayneLeaf's Avatar
New flywheel it is
Spikejmh
Feb 24, 2015 10:09 PM
GRok25
Mar 18, 2011 08:10 AM
brycerice13
Mar 20, 2010 05:16 PM
