New clutch question, NLS?
Old Aug 30, 2012 | 01:51 PM
mmack104's Avatar
I got a clutchmasters stage 3 with clutchmasters aluminum flywheel and ever since I haven't been able to NLS, is it because it's not bled properly?
Old Aug 30, 2012 | 02:49 PM
T-Man's Avatar
Most likely.
Bleed the slave and all four corners of the car and try again (pressure bleed if you can, saves time).
Old Aug 30, 2012 | 08:28 PM
09TcSedan's Avatar
i THINK that there is clutches that are NLS capable and NO NLS capable...i THINK but ive thought i read that somewhere on here.
my buddy had a clutchmaster clutch (along with other mods) he NLS'd at the track and BOOM
3rd gear.
i think people will chime in
Old Aug 30, 2012 | 08:38 PM
donkeyballs's Avatar
3rd gear.
You can NLS with any clutch, but some are more forgiving than others. I don't recommend doing it with any after market clutches, but people do it without blowing the trans so its up to you if you want to take the chance.
Old Aug 30, 2012 | 08:46 PM
slapbetcommissioner's Avatar
Most people who upgrade there clutches are also Modded. More torque equals NLS bad idea. Everytime you shift normally you drop some boost and reduce torque and even when shifting fast it is easier on the transmission. when you NLS you are loading it with more boost and more torque. Third gear has more load and more traction first and second so you are more likely to blow it out. ESPECIALLY if you NLS!
A better clutch also slips less which puts more stress on the transmission as it cant blead any torque off.
All clutches can NLS as it is a computer algerithm and not a feature of the actual clutch.
Old Aug 30, 2012 | 08:58 PM
09TcSedan's Avatar
if your bone stock,people NLS all day. when you get an after market clutch,its kinda sketchy.
^^thanks for telling me otherwise
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
