New Member...with a problem. Step in
It was about 40 out when we datalogged it.....the temp just wouldn't go down. I just wanted to make sure that having this intake set up....will not hurt anything.
As far as narrowing down the problem....it has to be mechanical....because the readings on the laptop were great...no knocks of any kind or anything. The only negative reading was the IAT reading.
I'm going to swap out the actuator solenoid to see if it could possibly sure my problem. My friend that was datalogging could really feel the car "kicking in and out" like the wastegate was opening and closing...so hopefully the solenoid will fix it.....
What were your MAF readings and AFR readings at WOT? If you have the HP log file, take a screen shot of the part where the car is tripping over its nose and maybe one of the tuner guys on here can better diagnose the issue... the kicking and bucking sounds like my car every time it rains, under WOT the MAF is just freaking out... condesation in the pipes or something... I have swapped MAFs cleaned them, cleaned pipes, all is a temporary issue until the weather drys out and the car seems fine.
Ok well have you checked your sensors again? Just to make sure I am reading this right... when datalogging was that IAT1 or IAT2 you were reading... if it's IAT1 (maf, which is still in the intake tube right?) then I could see 113... but if its IAT2 which, I believe but I could be wrong, is one of your MAP sensors (the Tmap in the intake mani I think), then you might have a messed up sensor.
As far as the wastegate solenoid, I read that you removed and checked it. But unfortunately in these cars the wastegate is only one of about a bazillion things that has an effect on boost... a more likely culprit is a sensor acting up, followed by a Vac line leak, then a messed up bpv, then a messed up actuator, all that if there isn't still a boost leak somewhere that is being a little bitch to find.
Took the car to the dealer....they said they would look at it...and thats all. They said they will not do any work to it unless they find a warranty problem. They said they will reflash it for me for $160.00. The said they've "already done their part". Being complete asses about it.
They said "you bring a part in here that we put on....it could be a problem with the part!!" I told them that it's a damn GM part...it's under warranty! They do not want to listen to anything I have to say.
My question is....do you guys think I should pay the $160.00 to have it reflashed?
I would think it's the ECM itself before I thought it was the flash.
I also have two spare ECMs. If you would like me to ship one of those to you to get flashed with whatever tune you would like, I would be willing to do that, as well. Just let me know. I'm in the Christmas kinda helpful mood.
I'm just saying if you narrow it down to begin a bad ECM, I have one you can swap out and try. You'll have to get a tune put on it for your vehicle. The 3bar sensors would be tuned for in your HPT tune or Trifecta tune. If you're going to purchase an HPT or Trifecta tune, you might as well try it on your current ECM first. If you still have problems, then you can try my spare ECM. Your problem doesn't sound like the tune to me.
So...Vince should be able to override the GMS1 tune? Just making it a pure Trifecta Tuned ECM? No engaging the tune....just a tune that's always there 100% of the time? If this is true....I'll see if Vince can just override the GMS1 with his tune....and see if that improves anything...
If you work through a distributor, it's a little easier to get tune adjustments than if you buy the cable and do it yourself, but I think there's a deal going on right now for the cable. HPT is the way to go if you want to be able to monitor your car, but it's about $450. With HPT, you can also save your stock tune and flash it back.
Vince's tune is a different software, so it overwrites everything. You can store your stock tune and put it back on the ECM, but the dealership can tell a reflash if they look. Your Trifecta tune with have two selectable boost options controlled by the cruise control or traction control button. The boost levels are your choice and the button is your choice. It'll cost you double the amount the dealer is asking you, though. It'll be around $320.
So....your saying I would have 2 Trifecta Tunes on it basically? A little lost here...
Right now....I have the GMS1...which is on all the time. If I put it into COMP mode...the Trifecta is engaged...
I have a theory... but my theories don't usually make sense to most people...
Im assuming you don't have a scan tool that can read live data, so we can do this the fun way...
Take your air filter off and put your finger tips on the outer perimeter of the intake pipe with your palm as far away from the pipe as you can get it... (be careful as the intake may try to eat your hand).
get a friend to start the car and spool the turbo... holding at 1/4 throttle then holding at 3/4 throttle, dont bounce it off the rev limiter it will negate the reason for doing this.
Does the intake try to eat your hand? when holding at 1/4 throttle does the suction from your intake dissipate with time, same question for 3/4 throttle.
If your intake tries to eat your hand and stays like that, forget I posted this. If it doesn't, post and ill try to make the mess in my head make sense to you.
TheSandMan
Sep 20, 2015 06:02 AM
