New owner review
Old Sep 24, 2011 | 04:43 PM
  #76
SSlobalt's Avatar
There's supposed to be a tube for vac attached where that hole is, where the red arrow is pointing. I didn't read this whole thread, but if that hole is just a hole, then it's a vac leak.
Old Sep 24, 2011 | 04:51 PM
  #77
soundjunky's Avatar
Originally Posted by alerosaint
My kit is ... screwed down with one screw and no issues
oh?
Now I'm going to actually look to see if that's a blind hole or not.
Thanks for chiming in.
Old Sep 24, 2011 | 10:12 PM
  #78
rukkee's Avatar
I'm thinking that larger line with the braided nylon is hidding the vac line....... I circled in yellow where I'm pretty sure the vac line is connected ...... if you look close i circled the tabs of the clamp holding it on. I could be wrong thou..... I've never had to replace the stock one or install GM stage 1 before.
Old Sep 24, 2011 | 11:47 PM
  #79
soundjunky's Avatar
... OK, I stand corrected.
the second screw hole does not penetrate the charge tube - it bottoms out (I actually just verified this).
I say drive it for another day or so to see if hte torrential downpours (which do mess with stock cars) was the culprit ~ the intake horn is behind the passenger headlamp ~ maybe it sucked in a bunch of water!?
note the Solstice GXP has a water shield for it's GMPP intake/filter;
Service Component - Air Cleaner Pre-Filter 19155349 - Crate Engine Depot
...or at least I've read this as being called a water shield???
Old Sep 25, 2011 | 12:40 PM
  #80
rukkee's Avatar
Yep.... it sure looks like the hydro shield that K&N and Injen sells for their stuff.
Old Sep 26, 2011 | 04:07 PM
  #81
alerosaint's Avatar
bump for update
Old Sep 26, 2011 | 11:22 PM
  #82
na2boost's Avatar
bump for update
It's going back into the shop tomorrow. With the help from everyone on here, and my own testing, I'm 99% sure it's a leak. The car is now throwing P0507 (erratic idle) and P0236 (boost sensor) codes. In my experience after work on any part of an intake system, if you throw an idle code, it hunts, crashes, etc, 99% of the time it's a leak.
You guys pointed out that the lower TMAP sensor is problematic, so I'm betting that's where the problem is. Only other thing I can think of is a collapsed bypass valve diaphragm, which I can fix by installed the forge valve.
Will get back to you guys once we have a solid answer. In the meantime I've been flogging the **** out of the Z06 to keep my sanity.
Old Sep 27, 2011 | 04:02 AM
  #83
alerosaint's Avatar
lol...as you should be doing
Old Sep 27, 2011 | 05:42 PM
  #84
asanti's Avatar
If you haven't gotten the car back yet, have them check to make sure the flash was done correctly. IMO have them check the lower TMAP as has been suggested to make sure it's sitting flush. The location for that sensor is a PITA to work with whether it's a dealer tech doing it or a DIY'er in his garage.
Later
Allex
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
jas09ss
Sep 26, 2015 01:06 PM
