New TSB wastegate
Old Jul 23, 2009 | 02:13 AM
rukkee's Avatar
New TSB wastegate
Service Information
2009 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | View All Bulletins | Document ID: 2312877
#09-06-93-004: Intermittent MIL/Check Engine Light On, DTC P0299 or P0234 Set (Adjust Turbocharger Wastegate Actuator) - (Jul 21, 2009)
Subject: Intermittent MIL/Check Engine Light On, DTC P0299 or P0234 Set (Adjust Turbocharger Wastegate Actuator)
Models: 2008-2009 Chevrolet Cobalt, HHR
2008-2009 Pontiac Solstice GXP
2008-2009 Saturn SKY Redline
2008-2009 Opel GT
2008 Daewoo G2X
with Engine RPO LNF and LDK (Europe)
Please Refer to GMVIS
Condition
Some customers may comment that the SES light is on. Upon inspection, you may find DTC P0299 (Turbocharger Engine Underboost) or P0234 (Turbocharger Engine Overboost) set.
Cause
This condition may be caused by a mis-adjusted wastegate.
Correction
Note: The wastegate adjustment is sometimes a very fine process. When adjusting the wastegate, only small adjustments should be made. Loosen one nut at a time and only adjust the nut one turn at a time; then tighten the other nut against the shaft and test drive to verify. This may have to be performed several times to achieve the desired boost level. To ensure proper adjustment, the vehicle should be at full operating temperature when testing. The vehicle will be very hot and may need to cool between adjustments. Too large of an adjustment can cause repeat DTCs.
Adjust the turbocharger wastegate. Refer to Turbocharger Wastegate Actuator Adjustment in SI.
Troubleshooting Tips for DTC P0299 - Turbocharger Engine Underboost
To increase boost, adjust the nuts (in) towards the actuator; in essence making the shaft shorter.
Troubleshooting Tips for DTC P0234 - Turbocharger Engine Overboost
To reduce boost, adjust the nuts (out) towards the end of the shaft; in essence making the shaft longer.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J5799*
Use Published Labor Operation Time
*This is a new labor operation number. The next update of the Labor Time Guide will contain this number.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2009 General Motors Corporation. All rights reserved.
Old Jul 23, 2009 | 04:39 PM
gatekeeper's Avatar
This is interesting.... The ECU should be able to vary its boost strategy and solenoid control to compensate for a wide range of WG arm adjustments. Unless the arm was waaaaaay loose, or waaaaaay tight. In either case, the car would have had problems from the start. Don'tcha think?
Old Jul 23, 2009 | 04:57 PM
Permafried-'s Avatar
Jesus did GM go on some crazy "TSB release" tangent or something
Old Jul 23, 2009 | 05:10 PM
umrdyldo's Avatar
actually yes.
Old Sep 21, 2011 | 05:06 PM
Buzz65's Avatar
My car is currently at GM for this adjustment. I noticed a louder than normal "woosh" noise when going full throttle. The initial power was just fine such as when passing someone or a brief 'goose' of the throttle. However, if/when you go full throttle, and leave for extended period (more than 5 seconds) the 'woosh' would get excessively loud and power seemed to flatten out drastically. Eventually I got the check engine light. The Chevy Tech said it was for low boost. Which confirmed my suspicions that I was losing boost somehow. They (Chevy) mentioned this bulletin to me and said that they were adjusting it.
They're going to give me a call when they're done this afternoon.
Old Sep 21, 2011 | 05:49 PM
mkulrey13's Avatar
subed for later read.
hacadacalopolis
Oct 28, 2015 06:09 PM
satisfied
Oct 19, 2015 12:35 AM
jcarroll53
Sep 24, 2015 07:43 PM
Adam144
Sep 3, 2015 07:48 PM
