is this normal
is this normal
When I nls there's some popping and almost like a pause is power then it kicks right back in
Mods are trifecta tune(just got it) and a 3in dp and muffler delete
not doing it fast enough or too close to redline.
It will probably pop when you do it, but you are probably doing it just a tad late. When are you going to nls...oh and between what gears? 1->2 is @#$@#$@# worthless.
I just nls'd a little bit ago from 2nd to 3rd and something went wrong and my check engine light came on and it started accelerating weird. then i felt it go back to normal and the check engine light turned off. no tune on my car
might have been because i did it on a cold engine because i was happy to be off work
car NEEDS to be warmed up
You have to do it before redline
You have to do it fast enough
So I haven't done it since....
When y'all nls, you're wot, clutch, shift, clutch... Right? Or did I miss a step?
My car has always been warmed up, an it was never frm 1-2nd
Well even before I tuned, it still never felt smooth, always jumped to redline whenever I hit the clutch. It never felt like I was suppose to do it... When I got tuned it felt smoother, but I heard noises an felt like I was breakin somethin lol really tho....
Question though: has anyone told a passanger about the NLS feature, gone to demonstrate it, but instead of hitting the gas you slam on the brake? Its good fun, you should try it!
Nls'n is NOT covered undered warranty..
Doin that an claimin its the reason you're transmission is shot won't cover ****...
NLS never really worked that well for me, and I couldn't find any in dash videos of someone doin it so I don't know how it's "supposed" to look/feel like
roth
Sep 26, 2015 12:16 PM
