The Official "I'm on a Big Turbo" Thread
#51
linky link for you:
http://www.spracingonline.com/store/...ool_Valve/3659
basically blocks off one side of the split turbine housing so that it forces all air to go through one side and then open up once it gets to a certain psi. It effectively decreases the A/R size.
#52
Wow i have never heard of that. Then it opens up at a certain boost level i assume so you back to your original a/r?
Would that be completely stupid on something like a Precision 5557? I would imagine that the spool would hit so damn quick that traction/tranny problems would be really apparent
#53
Turbo LSJ...not fully tuned just yet
-forged internals
-ZZP stage 2 turbo cams
-ZZP #82 valve springs
-ZZP BRFP and fuel pump rewire
-LSD trans swap
-400 hp axles
-3" side-pipe exhaust
-custom turbo setup, 25lbs boost
Turbo:
Garrett GT3076R (aka GT30R aka GT3037) Ball Bearing Turbo : atpturbo.com
Turbine
-Wheel: 60mm w/ 84 trim
-Housing: .63 ar
Compressor
-Wheel: 76.2mm w/ 56 trim
-Housing: .60 ar
**** doesn't spool til 5k which sucks but pulls like a **** afterwards. redline @ 7200
-forged internals
-LSD trans swap
-400 hp axles
Turbo:
Turbine
-Housing: .63 ar
Compressor
-Housing: .60 ar
#55
-forged internals
-LSD trans swap
-400 hp axles
Turbo:
Turbine
-Housing: .63 ar
Compressor
-Housing: .60 ar
-forged internals
-LSD trans swap
-400 hp axles
Turbo:
Turbine
-Housing: .63 ar
Compressor
-Housing: .60 ar
#56
This thread Rocks! Can anyone with a S256et let me know how good of a Turbo it is? I am very Interested in hearing opinions about how the spool is and top end performance, Seriously considering this Turbo but I wanted something with similar spool time of the K04 but didnt want to spend $2,000 for the ZFR.
#59
#62
-forged internals
-LSD trans swap
-400 hp axles
Turbo:
Turbine
-Housing: .63 ar
Compressor
-Housing: .60 ar
-forged internals
-LSD trans swap
-400 hp axles
Turbo:
Turbine
-Housing: .63 ar
Compressor
-Housing: .60 ar
#64
Ur right scobaltss is running the same turbo I think his full spool is before 4k too... But he did say he wasnt fully tuned, once his tune is done he should see decreased lag
#72
