The Official "I'm on a Big Turbo" Thread
Old 10-11-2012, 03:23 AM
  #51
BlkWdoSS's Avatar
Originally Posted by FrossB
elaborate/link to info on that?
linky link for you:
http://www.spracingonline.com/store/...ool_Valve/3659
basically blocks off one side of the split turbine housing so that it forces all air to go through one side and then open up once it gets to a certain psi. It effectively decreases the A/R size.
Old 10-11-2012, 03:26 AM
  #52
Thread Killer
FrossB's Avatar
Wow i have never heard of that. Then it opens up at a certain boost level i assume so you back to your original a/r?
Would that be completely stupid on something like a Precision 5557? I would imagine that the spool would hit so damn quick that traction/tranny problems would be really apparent
Old 10-11-2012, 08:55 AM
  #53
harryresh's Avatar
Turbo LSJ...not fully tuned just yet
-forged internals
-ZZP stage 2 turbo cams
-ZZP #82 valve springs
-ZZP BRFP and fuel pump rewire
-LSD trans swap
-400 hp axles
-3" side-pipe exhaust
-custom turbo setup, 25lbs boost
Turbo:
Garrett GT3076R (aka GT30R aka GT3037) Ball Bearing Turbo : atpturbo.com
Turbine
-Wheel: 60mm w/ 84 trim
-Housing: .63 ar
Compressor
-Wheel: 76.2mm w/ 56 trim
-Housing: .60 ar
**** doesn't spool til 5k which sucks but pulls like a **** afterwards. redline @ 7200
Old 10-11-2012, 10:39 AM
  #54
Nfamous60's Avatar
could make ur 5557 spool like stock turbo def might get for my 5857 after i upgrade to 5862 though.
Old 10-11-2012, 10:51 AM
  #55
kxrida2000's Avatar
-forged internals
-LSD trans swap
-400 hp axles
Turbo:
Turbine
-Housing: .63 ar
Compressor
-Housing: .60 ar
that seems pretty high of an rpm to spool a turbo that isnt very big
Old 10-11-2012, 11:48 AM
  #56
Sully20's Avatar
This thread Rocks! Can anyone with a S256et let me know how good of a Turbo it is? I am very Interested in hearing opinions about how the spool is and top end performance, Seriously considering this Turbo but I wanted something with similar spool time of the K04 but didnt want to spend $2,000 for the ZFR.
Old 10-11-2012, 01:52 PM
  #57
raver0789's Avatar
You will love. Spool is quick and top end is insane. Full boost 3.6k. Very efficient...low intake temps...
Old 10-11-2012, 02:22 PM
  #58
Nfamous60's Avatar
^^ Man i dont have a S256et but it was a neck and neck battle between that and my pte5857 price was the deciding factor, from what those with it will tell you is...IT ROCCS gud spool and great power potential.
Old 10-11-2012, 02:29 PM
  #59
SSlobalt's Avatar
You won't be able to install the S256 for less than the ZFR because of all the other parts you have to buy to install it. The ZFR is bolt-in, and therefore cheaper.
Old 10-11-2012, 03:11 PM
  #60
FasterIsBetter's Avatar
S256ET makes slightly more power. Plus running the kit means you aren't restricted to 500whp on the stock manifold like the ZFR.
Old 10-11-2012, 03:14 PM
  #61
Agreed. Sounds like tuning issues or an exhaust leak. Maybe even a very large boost leak.
Old 10-11-2012, 05:07 PM
  #62
SSlobalt's Avatar
I was just speaking to his comment about not wanting to spend 2K. He certainly can't have the 256 on there for that much.
Old 10-12-2012, 01:45 AM
  #63
BlkWdoSS's Avatar
yep it opens back up so that you are to your normal AR size. If you have a split housing on your 5557 it will help, but I do think you will have to run better tires and monitor your abuse
-forged internals
-LSD trans swap
-400 hp axles
Turbo:
Turbine
-Housing: .63 ar
Compressor
-Housing: .60 ar
that is horribly slow for that turbo, pm SCCobaltSS, I believe that is the turbo that he is running, Ill have to text him to see what he spools at. It seems to me that you have a massive boost leak somewhere.
Old 10-12-2012, 02:46 AM
  #64
FF_ace's Avatar
Ur right scobaltss is running the same turbo I think his full spool is before 4k too... But he did say he wasnt fully tuned, once his tune is done he should see decreased lag
Old 10-12-2012, 03:40 AM
  #65
Ah, I gotcha
Old 10-12-2012, 01:01 PM
  #66
Nfamous60's Avatar
^^^ nice numbers hows the tranny?
Old 10-12-2012, 06:14 PM
  #67
Just fine. On a ZZP Stage 2.
Old 10-13-2012, 12:46 AM
  #68
Nfamous60's Avatar
damn i want one, let me buy urs..
Old 10-16-2012, 09:05 AM
  #69
Nfamous60's Avatar
bump this
Old 10-16-2012, 10:16 AM
  #70
Cobe's Avatar
oh I cant wait to till I'm aloud to post in here hahah incredible numbers guys
Old 10-16-2012, 11:39 AM
  #71
Oh you can post in here without a big turbo! Just no one will care ahah!
Old 10-16-2012, 12:13 PM
  #72
Cobe's Avatar
lol ill keep my wittle snail to its sell...
ZFR coming soon (: Coilovers or ZFR... this winter... I cant decide..
Old 10-16-2012, 02:26 PM
  #73
Nfamous60's Avatar
ZFr fucc coilover get yyz spring n koni shock/struts n ur good.
Old 10-17-2012, 07:57 AM
  #74
Cobe's Avatar
I feel as if just being fully bolted with a good clutch isnt strong enough for the ZFR... am I wrong? Anyone on here with a just fully bolted LNF with a zfr?
Old 10-17-2012, 08:01 AM
  #75
Thread Killer
FrossB's Avatar
i dont get what you are asking.
Quick Reply: The Official "I'm on a Big Turbo" Thread
