Oil consumption issue???
Tell your dealer to look up this document number and then ask them what excessive oil use is .....dipshit dealer
I know it's posted above but this has the doc. ID that you can take in and have them look up.....while you watch
Service Information
Home Publications Number Search New Bulletins Bulletin Search Feedback Help
2009 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Engine | Engine Mechanical - 2.0L | Diagnostic Information and Procedures | Document ID: 42519
Oil Consumption Diagnosis
Excessive oil consumption, not due to leaks, is the use of 0.9 L (1 qt) or greater of engine oil within 3 200 kilometers (2,000 miles). The causes of excessive oil consumption include the following conditions:
• External oil leaks
Tighten bolts and/or replace gaskets and oil seals as necessary.
• Incorrect oil level or improper reading of oil level indicator
With the vehicle on a level surface, allow adequate drain down time and inspect for the correct oil level.
• Improper oil viscosity
Use recommended SAE viscosity for the prevailing temperatures.
• Continuous high speed driving and/or severe usage
• Crankcase ventilation system restrictions or malfunctioning components
• Valve guides and/or valve stem oil seals worn, or the seal omitted
Ream guides and install oversize service valves and/or new valve stem oil seals.
• Piston rings broken, improperly installed, worn, or not seated properly
Allow adequate time for rings to seat. Replace broken or worn rings, as necessary.
• Piston improperly installed or mis-fitted
© 2010 General Motors. All rights reserved.
Service Information
Well its time to bump this back up.
First, I want to say that dealing with GM is a nightmare. I hope I never have to do that again. I was getting acused of engine braking to much and driving to hard, over the phone, because it was a 5 speed turbo car....WTF?
I won't make this long, I started a arbitration process and then GM changes their mind and decides to help me. They tell me to go to a different dealership for a 2nd look. After doing another oil consumption test, and putting on a differnt valve cover (different baffling) they finally pulled the spark plugs and found build up on the #4 plug. They pulled the head and found this
So they got a new engine in and I have had my car back about a week. They said that since it has been burning oil its whole life, that durring the initial build of the engine the ring either got rolled and broke or was just a defective ring. Yay for a friday engine
Lets see how this one works out...
