OMFG BYTuned - 31+ VE
Old Sep 25, 2009 | 12:48 PM
MoePwR's Avatar
Thumbs up OMFG BYTuned - 31+ VE
Went to nick at byt and 10x better. Raced a trailblazer ss on ride home and kept up
Old Sep 25, 2009 | 01:11 PM
Iam Broke's Avatar
It's pretty awesome, huh??? Glad your happy.
Old Sep 25, 2009 | 01:24 PM
MoePwR's Avatar
ya its crazy.... his tune is the best ive scene so far. im boosting 25!
Old Sep 25, 2009 | 01:25 PM
G85 SS's Avatar
*seen
*bewst isnt everything.
Old Sep 25, 2009 | 01:27 PM
MoePwR's Avatar
lol no **** but timing isnt either and others are out of wack.
steviepc7's Avatar
you should be able to keep up with a trailblazer ss stock
Old Sep 25, 2009 | 01:31 PM
MoePwR's Avatar
its safe boost though. and no knock and afr looks great im goin to update a graph later.
it wasnt really a race he just sped past me and i gunned it and pretty much remained even with the distance between us. dont those have 400chp?
Old Sep 25, 2009 | 01:32 PM
G85 SS's Avatar
What's your AFR and Timing?
Old Sep 25, 2009 | 01:35 PM
MoePwR's Avatar
12 1/2 and 15 degrees
northvibe's Avatar
uhh......are you sure? hell no from a dig.
HB_SS/TC's Avatar
Noon quest but what's VE and can interceptors read it?
Old Sep 25, 2009 | 01:42 PM
raynrishad's Avatar
Dynograph!!!!
Old Sep 25, 2009 | 01:43 PM
MoePwR's Avatar
he went on vaca ill put it up when he sends it
Old Sep 25, 2009 | 03:23 PM
SSlobalt's Avatar
I understand not one thing in this thread.
Old Sep 25, 2009 | 03:27 PM
Projekt's Avatar
i've beaten TBSS..i guess thats cool
27 PSI ftw.
Old Sep 25, 2009 | 03:42 PM
ChrisBTCSS's Avatar
What is the difference between VE and maf/lb flow? I just got tuned and wanna see what the difference numbers are for me.
Old Sep 25, 2009 | 05:07 PM
RED08SSTC's Avatar
lol i heard that mine would do work on one of those yeah their 400 hp but its a big ass suv not sure on exact weight but its a hell of alot more than 2900
Old Sep 25, 2009 | 05:26 PM
G85 SS's Avatar
Isn't that a little rich for a LNF? I thought they could pull mid 13 AFR's without issues? See if you can crank the timing some more. Bump it until you knock, then pull a degree at a time until you see no knock.
I'm holding 26* of timing with 12.0 AFR on my car.
Old Sep 25, 2009 | 05:49 PM
MoePwR's Avatar
why not be safe and still have plenty of power?
Old Sep 25, 2009 | 07:45 PM
Terminator2's Avatar
MAF is the flow recorded by the mass air sensor on the car. It can easily be skewed by intakes and sometimes MAF table manipulation. VE airflow is the actual airflow measured at or near the turbo. It is always less than MAF flow because of the pumping and other frictional losses associated with the whole combustion process. Anything over 30 lbs/min VE airflow is great but it depends on gear selected. For example, I have seen 31.7 lbs/min VE airflow in 1st gear, 30.5 lbs/min VE airflow in 2nd, and 29.8 lbs/min in 3rd and 4th because it is a OD gear I normally see only 28.4 lbs/min VE airflow.
Old Sep 25, 2009 | 07:57 PM
HB_SS/TC's Avatar
Again do interceptors read this?
Old Sep 25, 2009 | 08:01 PM
26* will not happen on an LNF motor even on C-16. For the most part anything over 17* is a complete waste as far as peak timing goes unless you are running very high octane fuel. I run 13.0-12.9 A/F on my car.
I dunno I have no experience with interceptors. I can read it with my scanner that is all I know.
Last edited by Terminator2; Sep 25, 2009 at 08:01 PM. Reason: Automerged Doublepost
Old Sep 25, 2009 | 08:53 PM
MoePwR's Avatar
that was in 3rd gear. ill spin through 2nd way to easy and i cant believe how fast boost builds now.
Old Sep 25, 2009 | 11:10 PM
09SS's Avatar
Any dyno numbers Jon?
Old Sep 26, 2009 | 12:21 AM
MoePwR's Avatar
not yet. but power is rediculous
im goin to smg asap to get dynod easily over 300. trifecta had me at 275
