P0100 code again
Old Oct 28, 2011 | 01:18 PM
bspeed's Avatar
P0100 code again
2009 SS/TC 28k on the car as of today
been throwing the code for some time, weird this is i have zero boost issues and no drivability issues idles smooth etc. just annoying code/
I'm thinking a wire was rubbed or pulled out of the ecu
and the intake is back to stock etc. anyone know how to test the wiring? i also cleaned the maf sensor, nothing changed. code comes back on 2nd start. every time about 4 sec after engine is running... also reset the ecu and did the battery thing.
Old Oct 28, 2011 | 01:45 PM
SSlobalt's Avatar
Your choices are:
1) Boost leak test. See my sig for link. It really does sound like a vac leak to me.
2) Buy some MAF cleaner and clean the MAF. (nvm, I see you already did this)
3) Buy a new MAF sensor and try that or switch out with a buddy if you know someone else with a turbalt.
4) Check the MAF connector for pulled wiring or a pulled pin in the connector. Replace connector if damaged.
5) Replace the ECM. This is the last-ditch effort.
Old Oct 28, 2011 | 01:57 PM
bspeed's Avatar
Originally Posted by SSlobalt
Your choices are:
thanks for the tips
but if its a boost leak my car wouldn't boost at all right? my car is boosting like it did when i bought it 15psi
and the connector looks fine no wires pulled...
Old Oct 28, 2011 | 02:07 PM
duffman11's Avatar
Originally Posted by bspeed
thanks for the tips
99% of the time it will. That being siad you are the 99% that makes up the 1% that it doesn't! (follow that?) It could just be a small leak/lose hose/pinhole/piece of dirt...I would make sure when you cleaned the MAF you didn't break anything. Make sure it's still looks good. dont want to break the sensor!
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
