Is this a part of the intercooler system, or just a skid plate for it?
Old Jul 26, 2010 | 06:02 PM
DavidW's Avatar
Like the title says, heres the pic:
Uploaded with ImageShack.us
I'm not sure, it seems like just a skid plate, but their are rubber seals, so I am kind of confused.
Old Jul 26, 2010 | 06:06 PM
donkeyballs's Avatar
sure is..
Old Jul 26, 2010 | 06:12 PM
Wangspeed's Avatar
I really wish someone would sticky this.
https://www.cobaltss.net/forums/08-10-ss-turbocharged-general-discussion-152/remove-your-intercooler-condensation-pipe-212936/
David, I hope you removed that on purpose. If you hit something, there's a chance that your intercooler end tanks are now cracked.
Old Jul 26, 2010 | 06:19 PM
DavidW's Avatar
ahhh, the plastic mounts for the hinged side were cracked off, but it was still on their, I removed it,
posted this, went back out, zip tied it on the hinged side, and bolted it back up on the other side,
then came back to read these responses, I'm considering removing it all together now
Old Jul 26, 2010 | 06:36 PM
Wangspeed's Avatar
Remove, and epoxy/jbweld the holes. Check your end tanks for leaks!
Old Jul 26, 2010 | 07:01 PM
ronn's Avatar
Condenser collector for moisture that's why it's *tubed* into the intercooler via the holes on one side. They need to be plugged up good if you're gonna remove it.
Old Jul 26, 2010 | 07:32 PM
DavidW's Avatar
What do you guys think about shortening this, by cuting it and welding where it was cut?
Old Jul 26, 2010 | 10:36 PM
PrincessTurbo's Avatar
would be just fine....
Don't even need that stupid thing unless you get some sort of head gasket issue and it spews fluid out the manifold .
Old Jul 26, 2010 | 11:06 PM
fakameanrepresent's Avatar
i removed it last week, jb weld it, boost leak test it 2 days ago, and the result is no leaks so i'm good.
Old Jul 26, 2010 | 11:18 PM
DavidW's Avatar
Well the idea does make sense behind it, and i saw some sort of tsb for the solstice, and sky that says condensation can form in the charge pipes
Jan 12, 2016 12:01 AM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
dieGone
Oct 1, 2015 06:27 PM
Sep 27, 2015 08:53 PM
