part # for vacuum tank?
Like title says anyone know the part number for the vacuum tank under the intake mani? Or the actual name? Also anyone know the size of the vaccum lines? Thanks in advance
Well im trying to either bypass whole tank or replace it. I know how to bypass but idk if that would case me any problems in the long run
Couple threads pertaining to the tank.
https://www.cobaltss.net/forums/2-0l...ss-mod-208802/
https://www.cobaltss.net/forums/2-0l...st-mod-191361/
Well idk what the heck happened today but i got traction lost today and then it went to power reduced mode. Stopped the car amd it was running super bad sounded like a bad vacuum leak. Havent done the tank delete yet
When you said you lost traction, did you hit the rev limiter?
When you said you lost traction, did you go from full boost to completely letting off the gas pedal? If so, you likely slipped a clamp on one of the pipe connections at the IC. See pic below. I've had that happen twice before.
Nope i wasnt even on boost i was making a turn at maybe 20mph lost traction then it went into limp mode after maybe 100 meters after i made turn i was just coasting down the road then i tried to get in gear and it didnt wanna respond so i stopped the car it was making some weird noise. I turned off the car started it back up and everything was back to normal
Also did the tank delete didnt help one bit my car still is making a sound like if i have a goat inside it. its pissing me off but what can i do. already replaced my bpv solenoid and bpv to a forged unit but hasnt helped a bit.
When i replaced the solenoid it worked good for almost 1 week then it started again i probably need to backprobe the solenoid connection to see if its working correctly
I cracked my vacuum tank wide open on the stock turbo, 26psi E85 tune going around at the road track lol, replaced under warranty. I've had it bypassed most of the time since then. Doesn't seem to affect anything, one way or another.
Lol well i think mine got worse with the tank delete lol im going to install it back on wed when i have access to a lift. But still idk what else to check. Would a small crack on the ic or lower/upper pipe case that kind of problem? Also shouldn't that give me a cel?
no it doesn't change the power, just the sound of the bpv a little. mine was bad and would not let me boost past 15 psi, it would keep opening the bpv. got rid of it, not a problem after. can say how much I hate plastic crap on a engine.
As for CEL. When I blew my driver side lower pipe off the intercooler it wasn't setting a code. But my got the turbine sound coming out of the pipe was obvious.
Hmmm then yeah ill check my pipes. I mean as far as the IC goes i know i havent hit but what do i know lol. Anyome else has any ideas on what i could check
"t i got traction lost today and then it went to power reduced mode. Stopped the car amd it was running super bad sounded like a bad vacuum leak"
did you hit the limiter? loosing tracking generally wont break a car.
you have or have not checked the intercooler? you dont need to smack it for it to crack.
