Planning, preparing and putting together a plan for my LNF
Old Mar 25, 2014 | 12:43 AM
Jasn23's Avatar
I have an '08 black cobalt ss/tc. Right now she's pretty banged up and has a massive boost leak somewhere (so I believe and hope that's all). I haven't had a license in over a year but with my driving privilege returning soon, I'm preparing to work on her.
So i kind of have a few mods in my head I'd like to do and I'm actually hoping some of this subsequently fixes any existing problems.
What I need from you guys are suggestions, advice, and help with any questions I may have. Also any of those "well if you going to do this, might as well do this too" suggestions. Also opinions on brands.
So here we go:
1) cold air intake
2) zzp intercooler kit (hoping this is where I find my boost leak.)
3) long tube header
4) new down pipe w/ cat
5) clutch stage 2 or 3
6) zzp pcm replacement with tune stored on it.
Old Mar 25, 2014 | 01:29 AM
tuned08ss's Avatar
Lnf only needs downpipe not long tube header
Old Mar 25, 2014 | 01:31 AM
cw383's Avatar
Sounds like a solid plan. Scratch the long tube header. Not needed or even available on the TC. I have seen them for turbo fabrications but not a long tube style. Dont drive like a nut either. You might get away with the factory clutch for awhile too. Have fun!
Old Mar 25, 2014 | 01:48 AM
Jasn23's Avatar
Okay.. Is there any benefit in switching from stock manifold to anything else at all? And yeah I figured I could get away with stock clutch for a while but figured it's gonna go at some point so may as well change it so I can be a little rough on her without worrying about it.
Old Mar 25, 2014 | 01:57 AM
cw383's Avatar
Not really, I dont think our turbos's really like or need headers. If you win the lottery or something you may want to consider an LSJ ( Supercharged ) 4.05 trans , Or better yet a Powell 4.45 if you can find one while the trans is out. Thats going to be the next weakest link..
Old Mar 25, 2014 | 02:26 AM
Jasn23's Avatar
Okay, thanks for the tip.. That's what I'm trying trying to figure out is what my weak points will be and what would most likely need replacing next so I can plan better.. So if I can run on the stock clutch for a little while.. i should just put money aside and swap out a tranny when I upgrade the clutch?
Old Mar 25, 2014 | 04:36 AM
Jasn23's Avatar
Also those 4.45 gears will fit in the F35 correct?
Old Mar 25, 2014 | 07:04 AM
Wert842's Avatar
Ya
Old Mar 25, 2014 | 01:51 PM
Jasn23's Avatar
Originally Posted by Wert842
Ya
Know where I can order a set of those gears? And about what's the cost on that? Would the 4.05 from the s/c be better if you drive all the time? I'm just a little unsure on gearing so low. Would you need to change anything on your axles going with the 4.45?
Old Mar 25, 2014 | 07:24 PM
Shortbus's Avatar
Lnfs use a turbo manifold not a header, no need to change it anyway. If you plan to stay stock turbo keep your stock clutch, it will last and be easier on the trans. You can get a trans built by Powell raceshop choice of 4.45 or 4.05.
Old Mar 25, 2014 | 08:19 PM
I wouldn't worry too much about the trans on the stock turbo.
Tupp
Sep 30, 2015 08:18 PM
goaliemo
Sep 28, 2015 01:37 PM
Rduncanss06
Sep 27, 2015 11:17 PM
Sep 27, 2015 08:53 PM
