Potentially new BIG problem!!!
Old Oct 22, 2010 | 03:03 PM
Wangspeed's Avatar
Most good aftermarket pipes are anchored. The Hahn are not. Honestly, I'd rather have stock than the Hahn pipes. I've seen them, and the way the stock ones flatten out aren't as bad as folks make it out to be.
That being said, I wouldn't mind swapping to ZZP charge pipes sometime.
Old Oct 22, 2010 | 04:26 PM
importkiller's Avatar
So, glad I have Injen pipes
Old Oct 22, 2010 | 05:03 PM
chudson91's Avatar
yea my bud brad had stock piping and the exact same thing happened. they had a recall on a couple of 09 with hot side piping. i have zzp and its bolted down and you cant move it at all. hahn was to overpriced and almost of company piping is the same size and same bends except injen and cia
Old Oct 22, 2010 | 06:15 PM
Matt M's Avatar
Lol, I thought this thread was 4 days old. Oops, didn't see the year. I guess the hood dent feature doesn't sound as bad, anymore.
Old Oct 22, 2010 | 07:11 PM
Balento18's Avatar
Arrow
This happened to me on my very first track day!! I made this with the help of a friend, Aluminum menages heat better than hann's metal, lighter too. This will solve the whole issue by keeping the pipe VERY secure and far from harms way. Any local shop can make this for you for sure.
Old Oct 22, 2010 | 08:08 PM
Wangspeed's Avatar
IMO, charge pipes should be made out of poor thermal conductors. Meaning aluminum is a bad choice. Unfortunately, that's what most people make them out of.
Old Oct 23, 2010 | 10:10 AM
Terminator2's Avatar
True especially for the coldside pipe but the stockers fail easily. Steel is not much better choice but that is what mine are made off.
Old Oct 23, 2010 | 04:33 PM
ronn's Avatar
The stock Cold stock pipe or both? I think issues with these come from 1) the clip on the Hot pipe mount which was *fixed* via recall 2) Aftermarket ICs witch may place more stress on the stock pipes. I have stock pipes/ IC and all is well.
Old Oct 23, 2010 | 04:37 PM
M-Dub's Avatar
get rid of the hahn pipes... problem solved...
I have CIA and they aren't even close to them
Old Oct 23, 2010 | 07:38 PM
Chevycobaltss3's Avatar
Shooot mine broke so I checked checked resistance from one side to the other side.. then solderd the broken connection back together and used abs epoxy and now,its good as new. Resistance is the same and car runs great. No more code.... when I epoxied it I had the connector point down so it wouldn't happen again. I know gm wants 388.83 for it and it'll take the deler 5 buissness days to get it... but in goood now. Its very unnoticable. ..
Old Nov 28, 2012 | 07:24 PM
  #36
WickedWhite's Avatar
Originally Posted by SUKXOST
Well.....so I think this is a completely NEW potential big problem:
If you've read another thread I've posted you know that once my wheels started to hop at the strip, I went into 2nd gear and my car immediately went into ENG PWR REDUCED mode (safe or limp mode). Well, I went over my car with the GM tech who fixed my car and this is what happened:
My (aftermarket)Charge Piping bounced up and down(the part that goes right over the fuel pump and sensor is the only part that really has a lot of play in it) during the wheel hop....and it popped down and broke the sensor. Not completely off, so that's why I could not find anything wrong visually when I checked it out. But the CPiping sits an inch or less above that sensor and it did not take much at ALL to bounce the piping and break it.
GM cannot just replace the sensor, they had to replace the whole ****** fuel pump too and it was $800. LUCKILY that tech kept it out of the eyes of the service manager since I was a cool loyal customer and they replaced it under warranty.
Now I'm terrified to go back to the track with it! Please try and find your own way to block or protect that sensor from being broken......and yourselves from having this happen!
I'm running stock cpiping and this just happened to me..
Warranty <3
Old Nov 28, 2012 | 10:13 PM
  #37
SSlobalt's Avatar
I have the stock charge pipes and this has never happened to me. Who has the better pipes, now?
btw, what is up with all the thread-resurrections, lately?
06MetallicBalt
Jul 20, 2025 08:47 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
