Problem with cold start.
So I just put a Full MPx Exhaust with catless DP and Muffler Delete. In the mornings when its warming up, it bogs revs high then low. Once u rev it up like 3 times it clears up. Sounds like something is clogged up... Tough to explain. Exhaust just sounds weird, but when it is warmed up its perfect..
Any suggestions?
Any suggestions?
ya u will just throw a CEL for the O2 sensor, so if u throw a code thats why, then when u get tuned tell them to turn the code off
and the cat warm up cycle will make the car rev at like 1500-2000 rpms when u cold start it to warm the cat up, so thats why it idles high then after a min it should go down to normal
I have a defouler and still throwing code. Once i get a bigger front mount im gettin it tuned. I might have to post a video tomm, cause i have never heard this before. The car shakes and feels like its going to just turn off. Its weird..
Nope thats it, and never had a problem before. IM Gm stage 1 and still perfectly hitting around 21 without no delay. Like I said, drives and feels fine after warm up. Just dont want to turn it on and one morning it blows or something lol
ya maybe with the skewed fuel trims and now the O2 sensor, it just makes it run funny
these cars are so damn picky sometimes lol
Last edited by 07SSYellow; Aug 23, 2011 at 02:35 AM. Reason: Automerged Doublepost
Sorry to revive an old thread.... But if you are having this problem then you need to change your oil.
That is what happens. Change your oil, and it should get sorted out. If you went without changing your oil, it would crank over, bog, and sometimes shut off, then it will try to restart itself.
roth
Sep 26, 2015 12:16 PM
OrangeCoba
Sep 25, 2015 06:06 PM
