The REAL Weight of Stock SS/TC Rims...
Old Apr 2, 2009 | 09:47 AM
TrevMo's Avatar
Alright...there have been tons of people out there saying they know now much the stock SS/TC rims weigh, but they are all different...I have seen anywhere from 22-26 LBS...and that is quite a large swing. Some people have weighed the entire wheel with the stock tires and have done some math (which is probably the closest we are going to get because I doubt many people have the stock rims sitting around without tires), but I'm not sure they had the correct weight for the stock Conti tires. I looked up the tire weight and the manufacturer says they weigh 26.2 LBS each.
Based on this weight, can anyone say WITHOUT A DOUBT how much the SS/TC rims weigh?
I found the tire weight on the following chart (the tires are 225/40ZR18):
http://www.conti-online.com/generato...tasheet_en.pdf
EDIT: I guess TireRack had them incorrectly listed as ZR instead of Z...the actual weight is 22.6 LBS each...
Old Apr 2, 2009 | 10:07 AM
Joemann892's Avatar
actually its 22.6lbs directly from your link.
225/40R18 NOT 225/40ZR18
EDIT: even tho on tire rack it says 225/40ZR18 it also says 92Y XL.
and i believe there is a typo and it should be 225/40R18 because that is 92Y XL.
Old Apr 2, 2009 | 10:15 AM
fingerling's Avatar
is tat heavy compared to after market rims
Old Apr 2, 2009 | 10:20 AM
TrevMo's Avatar
Hmmm...I went directly off of what TireRack said...but I don't have my stock tires with me (in storage)...can anyone confirm if they are ZR or just R?
Old Apr 2, 2009 | 10:21 AM
fingerling's Avatar
just r
Old Apr 2, 2009 | 10:25 AM
TrevMo's Avatar
Originally Posted by fingerling
just r
Looks like you are right...thanks TireRack....
Alright...can anyone do the math based on the tire weight being 22.6 LBS?
Old Apr 2, 2009 | 10:28 AM
Tomtwtwtw's Avatar
For what it's worth, a Y rated tire is also a Z rated tire. R and ZR are both acceptable.
Old Apr 2, 2009 | 10:32 AM
1badBlueberrySC's Avatar
Z, Y, W are all "Z" rated tires... the Conti's are a "Z" rated tire it's just usually it's called a "Y"
Old Apr 2, 2009 | 10:40 AM
TrevMo's Avatar
Lets get back on topic...
Old Apr 2, 2009 | 12:30 PM
Joemann892's Avatar
well there is no argument that they are 22.6 or lighter depending on tire wear.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
