rear brakes
Old Feb 1, 2013 | 07:27 PM
Topgear's Avatar
rear brakes
Hey anybody know of any upgraded brake s for the rear or brembo replacements. Cuz the calipers on the turbo ******* suck ?
Old Feb 1, 2013 | 07:29 PM
nobody2u's Avatar
Not many have changed the rear brakes on the LNF. There are no bolt on brembo replacements so serious custom work would take place to make a set fit back there. Also, changing just the rear brakes without upgrading the front with a matching set will throw off the OEM braking balance.
Old Feb 1, 2013 | 09:25 PM
Solaris99's Avatar
2nd nobody2u. I wouldn't want to throw off the bias. I started using Raybestos (I think) rotors and I got $20 pads at O'Reilly in kind of a bind. I didn't put pad lube on the pad backs (don't ask), but I did all the slides. When the rotors have some oxidation, I get noise from the rears, but it goes away after 2-3 good slow-downs I've checked for grooves on the inside of the rotors a few times and nothing. It's smooth and flat, and they work well with stock fronts. Used them 1 day on a track with CarboTech XP10s up front and they held up well.
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
