Spongy brake pedal issues
Old Jan 29, 2013 | 10:39 PM
Turbalted's Avatar
Hey guys looking for a little bit of help. My brake pedal is spongy and not sure what it is! I bleed the brakes and still feels the same. AllData says to have a scan tool hooked up while you do it so it can open and close the valves in the abs unit. I don't have access to one that will do that. So anyways, the pedal is spongy but will still stop the car. When the car is really cold, and I press the brake pedal down all the way, it feels like the abs is kicking in and pulsating the pedal. And my idle goes all funky when I do that, leading me to think its a vacuum line. And today I also noticed the pedal is even softer if I have the clutch pedal depressed at the same time. (Clutch uses brake master cylinder) what do you guys think??
I'm a 2010 and just rolled over 40,000 miles and have replaced the rear pads and rotors at 26,000 miles
Old Jan 30, 2013 | 05:30 PM
Turbalted's Avatar
Also, if I pump the pedal once while braking, and then once again the second pump is much stiffer how a brake pedal should feel
Old Jan 30, 2013 | 05:48 PM
Maybe master cylinders going bad?
Old Jan 30, 2013 | 11:02 PM
Knightwolf's Avatar
I have this problem also.. but not like you said previously.. I also bled my brakes when I did them.. probably going to redo them again this spring anyways so I'll try again and hopefully it'll be fixed this time around.
Anyways, curious to know more
Old Jan 31, 2013 | 12:11 AM
094doorSS/TC's Avatar
https://www.cobaltss.net/forums/2-0l...firmed-292429/. Something to look at.
Old Jan 31, 2013 | 12:43 PM
Turbalted's Avatar
That link is very helpful. I'll try that today
Old Jan 31, 2013 | 03:58 PM
Turbalted's Avatar
It worked!!! Ahh my pedal feels so much freakin better, and e brake is back to normal height. Thanks a bunch guys!
Old Jan 31, 2013 | 04:36 PM
sweet glad you fixed it.
Old Feb 2, 2013 | 12:47 PM
SSlobalt's Avatar
Unfortunately, I don't know how long this will last, or if it means we just need to replace the rear calipers.
Old Feb 2, 2013 | 01:12 PM
nRRe's Avatar
mine just started out of no where.
well, it started feeling a LITTLE spongey, then i didn't drive fro 2 weeks (was in the hospital for gall bladder removal/pancreaitis yay weightloss!) and when i drove it fort eh first time afterwards it almost feels like the brake pedal isn't there.
may have to look into that link posted.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Trav3480
Oct 1, 2015 08:17 PM
