Spongy brake pedal issues
Hey guys looking for a little bit of help. My brake pedal is spongy and not sure what it is! I bleed the brakes and still feels the same. AllData says to have a scan tool hooked up while you do it so it can open and close the valves in the abs unit. I don't have access to one that will do that. So anyways, the pedal is spongy but will still stop the car. When the car is really cold, and I press the brake pedal down all the way, it feels like the abs is kicking in and pulsating the pedal. And my idle goes all funky when I do that, leading me to think its a vacuum line. And today I also noticed the pedal is even softer if I have the clutch pedal depressed at the same time. (Clutch uses brake master cylinder) what do you guys think??
I'm a 2010 and just rolled over 40,000 miles and have replaced the rear pads and rotors at 26,000 miles
Anyways, curious to know more
https://www.cobaltss.net/forums/2-0l...firmed-292429/. Something to look at.
mine just started out of no where.
well, it started feeling a LITTLE spongey, then i didn't drive fro 2 weeks (was in the hospital for gall bladder removal/pancreaitis yay weightloss!) and when i drove it fort eh first time afterwards it almost feels like the brake pedal isn't there.
may have to look into that link posted.
