Rear Sway Bar Rubbing?
Old Mar 20, 2011 | 09:52 PM
  #51
MaxPsi's Avatar
so should i try some rubber, washers, enlarge the rear holes or grind down the rear sleeves?
Old Mar 20, 2011 | 10:45 PM
  #52
qwikredline's Avatar
no rubber, no washers, if the rear sleeves I expect both, but please wait...thanks....you have my email for fast response...
Old Mar 20, 2011 | 10:51 PM
  #53
MaxPsi's Avatar
will it help if i flip my nut plate?
Old Mar 20, 2011 | 11:58 PM
  #54
Wangspeed's Avatar
Still betting it's the exhaust for most people, and they do not realize it. From reading this thread, it's obvious that some people are checking it while it's unloaded, which is completely wrong.
Check the clearance to the exhaust while the car is fully loaded on the ground. Bet you can only get a finger or two in there if you're on Pedders. Guess what happens when you go over a bump?
Old Mar 21, 2011 | 02:54 AM
  #55
whyyoumadson?'s Avatar
^^^this is 100% true.
Old Mar 21, 2011 | 09:46 AM
  #56
mechanical lock nuts wont work in reverse. and the plate wont work that way, no no no....
Old Mar 21, 2011 | 10:00 AM
  #57
Today we are working on a solution to take care of two issues in the latest series of bars: #1 the larger forward hole in the twisting beam that allows the sleeve to go inside, and lock to the nut plate and not clamp the nut plate to the beam , and #2 the bar kissing the V beam. If this solution works, I will mail the update parts to you asap...the current production run may incorporate this change, not sure yet this is the news as it happens. Please contact me directly via email. thanks
Old Mar 21, 2011 | 11:42 AM
  #58
tom.g's Avatar
I checked exhaust while the car was down on the ground and it does not hit anything. That being said I have had the exhaust hangers adjusted bit that was because the shitty OTTP downpipe put the whole exhaust out of whack.
Old Mar 21, 2011 | 11:55 AM
  #59
ninja44's Avatar
My bar (1.0) is a a couple of mm away from the v beam but does not touch ever. When I got under the car last summer I was under the car pushing up on the sway bar (like bench pressing) and I had to use a lot of force to make it contact the v beam. No big deal and as you can see the old guy will make it right for those concerned
Old Mar 21, 2011 | 01:44 PM
  #60
Answer: not loose on the triall fit here no matter what I did. But contact with the V beam thats normal but if you dont like it I did put in a 4 mm thick washer on the leading (large hole) bolt (.187" zinc plated common washer) has to be squared off to sit flat on the twisting beam.
all good piktars later
Old Mar 21, 2011 | 09:38 PM
  #61
This the point of contact on the V beam
This is a piktar of two beams one made in fall 2009 (powdercoat has endured pretty well) and the latest generation textured black pc bar with 2009 bolts in place/2011 bars have longer bolts.
this is the 4 mm washer trimmed to install on the forward mounting point, which has the larger hole in the twisting beam itself.
this shows the washer in place
and this shows the clearance to the V beam.
This solution takes away from any chance that the bar sleeves are so long as to prevent the proper clamping of the bar to the beam, and further provides clearance to the V beam.
Today I found the new bar clamps fine without any washer to space it. I used 50 ft lbs of torque the bolt and plate can handle that no problem
Hopefully this is a suitable answer , for those who have contacted me directly via email I will mail out washers free of charge....thanks for choosing our hardcore race parts.
Old Mar 21, 2011 | 10:35 PM
  #62
RooTBeeR's Avatar
[IMG]http://i857.photobucket.com/albums/ab140/qwikredline/DSCF5294.jpg[/IM G]
[IMG]http://i857.photobucket.com/albums/ab140/qwikredline/DSCF5297.jpg[/IM G]
[IMG]http://i857.photobucket.com/albums/ab140/qwikredline/DSCF5305.jpg[/IM G]
[IMG]http://i857.photobucket.com/albums/ab140/qwikredline/DSCF5307.jpg[/IM G]
[IMG]http://i857.photobucket.com/albums/ab140/qwikredline/DSCF5309.jpg[/IM G]
so if i email you right now i can get those washers too?
Old Mar 21, 2011 | 10:40 PM
  #63
why not? u buy a bar from me, and want this, for sure... u got my email. wont ship until Thursday I am out of town...
Old Mar 27, 2011 | 12:32 AM
  #64
Update:
latest install Saturday with new spacer. units mailed to folks who asked ( 2)
Triple X bars on schedule shipping April 4 goodly stock of all bars and jack point UCR for those who asked.
Old Mar 27, 2011 | 12:12 PM
  #65
RooTBeeR's Avatar
yay! i can has spacer! lol
...as for my plans on the car, XXX will be over kill(other wise i would have already tried to sell it in prep for when the XXX comes out ). heck my Hardcore is probably already over kill for me but its still a lotta fun, and i wouldnt even think to step down to the Street bar
Old Mar 29, 2011 | 12:50 PM
  #66
07BoostedG5's Avatar
Just read thru this entire thread and all I can say is what a great person to do business with, I have never seen someone so involved with there product. kinda sad the best vendor here is not even a vendor, regardless this is a example of how a business should run.
A+++++++++++
Old Mar 29, 2011 | 09:49 PM
  #67
tom.g's Avatar
Hey qwikredline won't you need longer bolts with the new washers? Ps what is your email address?
Old Mar 30, 2011 | 02:05 PM
  #68
RooTBeeR's Avatar
qwikredline@hotmail.com
no, with that washer/spacer in there it will sit the same height as the rear bolt(that doesnt fit through the hole in the beam) so the original bolts are still long enough
Old Mar 30, 2011 | 07:45 PM
  #69
Thanks everyone your spacers are in the mail....btw, I found on a TC today that had gotten into an argument with a small shrub /tree whatever (rolled backwards when hand brake did not hold) that the fuel tank metal skid plate fasteners were broken ; could lead to rattle and banging. Also the brake/gas line brackets were damaged, i noticed that as when installing UCR you have to drop them down to clear the install etc.
so far so good/ enjoy your rides... for Tom G who started this thread i sent new bolts as well but as Rootbeer pointed out, not really needed...
Old Mar 30, 2011 | 11:17 PM
  #70
OBZ's Avatar
OBZ
Thanks for clearing all this up! You are a bad ass!
Old Mar 31, 2011 | 10:40 AM
  #71
tom.g's Avatar
Thanks again qwikredline!
Old Apr 1, 2011 | 07:48 PM
  #72
misfitz's Avatar
So how much is this bar? and where do I order this?
Old Apr 1, 2011 | 07:56 PM
  #73
RooTBeeR's Avatar
you email Gloria at gloria@powellmotorsport.com and tell her what you want. either the Street, Hardcore, or(youll have to wait for production to begin) the XXX Rear Sway Bar. make sure to include all your shipping info and she will contact you back with a price, then paypal the money and wait for the goodies to arrive in the mail!
Old Apr 10, 2011 | 07:55 AM
  #74
Note to Tom.G. I have found quite a variation in twisting v beams, some touch some dont. I did however find a TC with a street bar that contacted and "knocked' made a noise. Washer upgrade fixed it, and we will ship extra hardware with each bar going forward. All who asked have upgrade, expt ecocharge; I dont have an address for him for some reason.
PS XXX 1.5 bars are shipping...
Old Apr 10, 2011 | 11:38 AM
  #75
RooTBeeR's Avatar
"Like" this!
