rear whell ???
rear whell ???
ey guys i have a problem i think i may have a rock stuck in the between the pad a rotor but i can take a look because i cant figure out how to take the rear wheel off any help please thanks
Break Tires Loose with 19mm or 3/4" socket and Breaker Bar
Lefty Loosey Righty Tighty
Jack up Car
Pull off Wheel ?
my moms car did this. does it make a really high pitch, annoying as **** sound? i pulled the wheel off, kicked the rotor and bent the metal shield thingy around a bit, then it fell out
"I think I have a problem." - Do you or don't you? Perplexing?!?!
"I think I may have a rock stuck in the between a pad a rotor?!?! Dude, I got stuck in the between once. It was like eating a really bad ham samwich. AND WHAT THE **** is a APAD AND AROTOR?!?!
"but I can take a look" - So you can see in there. You LIAR!!!
"because I cant figure out how to take the rear wheel off" WHAT!?!?! So you lied again? ******* Lair!
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
